need help
Old Jun 15, 2006 | 12:15 PM
Scarface's Avatar
change cars like socks
Default need help
i just rebuilt my carburator on my capri its in running really rich and breaking up at high rpm's ....the carburator needs adjustment but i dont know how.....can some one help...thanks
Old Jun 15, 2006 | 12:26 PM
Little Nicky's Avatar
1140cc's of power
what kinda carb?Most have 2 little flat headed knobs to adjust air and fuel mixture.
Facebook
05 zx10r with a lot done still never will be stretched
Old Jun 15, 2006 | 02:33 PM
ODB's Avatar
ODB
S.Y.L.O.
yeah and they should be open only about a half a turn to start if I remember...then tweak them....and make sure your floats are not getting stuck open...
Old Jun 15, 2006 | 05:37 PM
Scarface's Avatar
its a holley 750 doable pumper ......i know about the 2 screws to adjust it but i dont know witch one is fuel and witch one is air......what kinda of fuel pressure should it be running at ??
Old Jun 15, 2006 | 05:39 PM
ODB's Avatar
ODB
S.Y.L.O.
4-6lbs......
Old Jun 15, 2006 | 07:08 PM
Shamus O'Toole's Avatar
Redneck Yatchclub member
Its a 750 on a 302?!!! Unless this is a realy stout motor, sounds like its over carb'ed to me.
Old Jun 16, 2006 | 04:28 AM
T/S #25's Avatar
Need To Get Quicker
Set your fuel pressure at 6 pounds.
Check your bowl levels so that fuel is just starting to run out when you pull the sight plugs.
Turn the adjuster screws all the way in and then back them out 1 to 1 1/2 turns and adjust from there.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Jun 16, 2006 | 04:33 AM
Scarface's Avatar
well its not a stock motor its mild 306 and i always had this setup and the ran really good ....good numbers too at the track
