sick and tired and need help !!warning lights
Old Jun 15, 2006 | 11:47 AM
seventhgear's Avatar
hanglike sleeve of wizard
Default sick and tired and need help !!warning lights
i have a 96 cobra and every so often my low oil light comes on as well as the brake! light. they both come on every so often and always at the same time. when the lights come on my a/c does not blow @ all. what can this be? some sort of fuse? some sort of relay goin bad? im stumped and i hate it. the lights always seem to turn on when i need to drive in the pouring rain and need the a/c .. please help!
thanks in advance
jack
image removed from your sig...see forum rules
Old Jun 15, 2006 | 01:49 PM
evocrazy1's Avatar
check your oil and brake fluid, when mine was low when i would accelerate they would come on, and then when i got on the brakes they would go out
ASKED TO BE BANNED
Old Jun 15, 2006 | 02:03 PM
i thought the same but its not it. then i thought maybe an abs prob but i have not checked on that just yet. but the oil light is whacky. it came on like the second time i drove it after an oil change. here is something a bit fishy goin on. why would the a/c go on the brink when the lights come on? weird shizzle
thanks tho man
Old Jun 15, 2006 | 06:15 PM
evocrazy1's Avatar
might be a body control module acting up
ASKED TO BE BANNED
Old Jun 15, 2006 | 06:18 PM
ohh shit and i almost forgot.... i am still having an idle prob with the iac valve getting too much or not enough voltage, and my odometer stopped working around the same time as the brake! light started showin up
Old Jun 15, 2006 | 06:37 PM
Road Rage's Avatar
Shake n' Bake
Sounds like you have a wiring problem, id take it to a place like Besco on waters and have them go through the wiring...
Old Jun 16, 2006 | 03:54 PM
where exactly are they located? have you had good experiences with them?
Old Jun 16, 2006 | 04:24 PM
Road Rage's Avatar
Shake n' Bake
They are on waters by the dog track, they do good work. They usually have alot of cars so it takes some time for them to do it but they went through my car i used to have and found the problem and fixed it and didnt charge me alot. Usually its a bad ground or two wires touching......
