New problem...........F%@k
Old Mar 22, 2006 | 03:14 PM
1Bad00SS's Avatar
Default New problem...........F%@k
It wont start, the silinoid is just clicking and on the first try about every 15min or so the trys to turn over then stops.
the relay that sits on the the silinoid will start to smoke as well as the power and the ground.
what the hell is wrong with my car.
Old Mar 22, 2006 | 03:45 PM
tony122's Avatar
when i first bought my fox,it did the same thing it turned out to be the starter try to hit the starter lightly with a hammer.. i bought mine from auto zone like 2 years ago for under 60 bucks...just an idea
Old Mar 22, 2006 | 05:12 PM
TheShow50h's Avatar
The little 5.0 that could
but what would cause the terminals on the battery side of the silinoid to get hot?
1Bad00SS
-Vince
Old Mar 22, 2006 | 05:20 PM
bigjim2.5's Avatar
bad connections ..clean all battery terminal starter and noid connections and make sure they are tight. or if battery voltage is low the resistance created trying to turn over engine will cause the terminals to get hot
Chad99gt's Avatar
99' GT
SOLENOID!!!***** sorry to hear about the beast not running mann
1999 Mustang GT 35th Aniversery
2007 Yamaha Raptor 700R
Old Mar 22, 2006 | 05:28 PM
primetime1267's Avatar
Smacking Her A$$
Does the starter/solenoid have a jumper wire on it? it may have come lose or fried..
Independent AMSOIL Dealer
XPSYNTHETICS.com
Sarasota, FL ZO#1863313
Old Mar 22, 2006 | 05:46 PM
TheShow50h's Avatar
What does that wire look like?
-Vince
Old Mar 22, 2006 | 07:44 PM
racingrick's Avatar
POTENTIALLY FAST
i'd probably throw a new starter on it if I were you...the reason your terminals are getting hot (you're about to melt them, or the wires, or fry your battery or alternator.........or everything) is the starter is trying to lock up, there's too much resistance in the line so the amperage is going back through your lines............kind of a laymans term but that's basicly what it's doing. can cost a whole lot more than a starter................another thing, I've personally had a lot of trouble with the rebuilts from the parts place, but if you pay an extra 20 bux, you usually get the new (not remanufactured one) and never have another problem..........or you can go to a junkyard and buy a starter off of a 3.8 v6, it's the small starter, just a slightly different wiring, will help you have less starter lock up probs!
Old Mar 22, 2006 | 08:23 PM
nasdstang's Avatar
need turbo stuff,pm me
when your battery is too low it will heat up the cables also, then when you let it sit it gets a surface charge. id try a different battery out of another car first
-Ronald Reagan
