Carb guys, fuel pressure acting up
Old Jan 20, 2006 | 09:51 AM
bottlefed93's Avatar
Default Carb guys, fuel pressure acting up
Just converted my 89 to carb and in the process of getting it dialed in, I set the fuel pressure to 7 psi. When I started it up cold it was 12 psi. After driving for a while I checked again it was at 4 psi. I have a brand new Holley blue and pressure regulator with steel braided line from tank to carb. It is 3/8 line. I was told that this is ok but it worries me. Why is my fuel pressure fluctuating so much? Thanks
Old Jan 20, 2006 | 09:52 AM
Steve B's Avatar
brings his heater.
reason number one to run a return fuel system.
Old Jan 20, 2006 | 10:45 AM
I will be running a return system in the future, but I am trying to get this dialed in as much as I can for right now.
Old Jan 20, 2006 | 02:13 PM
Zman's Avatar
I gota Cheby
When pressure is bypassing the needle and seats it will cause also eratic pressure. should be using Viton (spelling?) needle and seats. 100's of race cars use the blue holley without a return with no problems. on a street car though I would rec it to keep the pump cooler and keeping the pressure from spiking. Also check your regulator make sure its working by adjusting the pressure up and down. By the way thanks for the xpipe worked out great.
Only 1/4 mile track I know is Gandy Bridge
Old Jan 20, 2006 | 04:03 PM
T/S #25's Avatar
Need To Get Quicker
What kind of gauge are you using and where is it mounted?
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Jan 20, 2006 | 06:42 PM
Regulator is definately working. I believe its an autometer (it is liquid filled) and is mounted on the line going from the regulator to the carb.
Old Jan 20, 2006 | 08:49 PM
Duceanahalf's Avatar
is doing your girlfriend
my aeromotive system stays right at 5-6PSI (cant remember what it is set at). Im running 1/2" aluminum line and -8 braided hose before the regulator, from the reg. to the carb is 2 -6 braided lines.
Old Jan 21, 2006 | 03:46 AM
T/S #25's Avatar
Need To Get Quicker
I would check the gauge. If it really had 12psi going to the carb when you started it up cold, fuel would be pooring out the bowl vents.
I have seen liquid filled gauges do funny things when they are mounted in the engine compartment and are subjected to the heat. Barry Grant has a notice in the box when you buy one of their carbs stating "not" to mount liquid filled gauges near the engine or close to a heat source.
I have a Barry Grant 280 fuel pump on my car with #8 line to the regulator and #6 lines to the carb. No return line and the fuel pressure stays steady at 6 3/4 pounds. I will however have a return on the fuel side of the nitrous whenever I get around to installing it on the car.
It's just a guess, but it's worth a try.
Joe
FordSpeed Racing
9.78 @ 136.05
Old Jan 21, 2006 | 10:32 PM
You were dead on!! I put a new gauge in/ set it and it has not budged since. Thanks. Also owe a thanks to NA306Stang
Old Jan 21, 2006 | 11:58 PM
Na306StAnG's Avatar
Flowmaster nut swinger
Hey man glad all worked out. good to hear it was a simple fix you got my # give me a ring if you need anything else
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
