Installing Intake Manifold
Old May 4, 2005 | 08:18 AM
Big-D-Bo's Avatar
Sweet Lincoln's mullet
Question Installing Intake Manifold
I posted a earlier question about what lower intake manifold to go wiht for my 351W. The intake i went with is the Edelbrock RPM Air-Gap. I got it a few days ago and i want to install it myself tomarrow. The entire motor has been built by Sam at Coastal Dyno so i am hesitant to install it myself. I am being told it is real easy since A:the Motor is not in the truck B:it's carburated. My questions is can i get a crash course instruction on how? I know Get the gasket and some RTV silicone for the front and rear seal and torque bolts in star pattern to about 22lbs. Thats all i know, Anything i am leaving out?
Thanks for help.
Derek
-Derek-
Old May 4, 2005 | 08:46 AM
Big-D-Bo's Avatar
I forgot to add that i have no clue what gasket set i should go with. Any suggestions on that to?
-Derek-
Old May 4, 2005 | 09:14 AM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
Any chance you could have Sam @ coastal do it? I say that only because he built the motor. It isn't that hard to install it. Just have to make sure you criss-cross torque the bolts for even seating. Its a "wet" intake, if you mess up you could get water in the oil pan from an unsealed water jacket. I normally use a set of Fel-Pro Gaskets and some Sealant around the water jackets in the intake to make sure they seal. But everyone has their own way of doing it.
Derp!
Old May 4, 2005 | 09:36 AM
Big-D-Bo's Avatar
Tried Contacting Sam a couple times and no answer no call back... So i am going to try and tuff this one out. I have a friend helping that has installed quite a few of them but i am still kinda sketchy. I was going to get the Felpro Performance set.
http://store.summitracing.com/ Part FPP-1250. They offer one with a larger port to them i dident know if i should go with that.
-Derek-
Old May 4, 2005 | 10:23 AM
ODB's Avatar
ODB
S.Y.L.O.
make sure you put a nice glob of sealant on the front and rear corners were the gaskets meet.
Old May 4, 2005 | 11:25 AM
Big-D-Bo's Avatar
Yeah i was told to use the RTV sealant for front and back seals, Around the water jackets aswell.
-Derek-
Old May 4, 2005 | 09:04 PM
freakyfast95GTS's Avatar
Ghillied up and ready.
use a 1/4 or bigger bead of rtv or they'll leak, new Cheese whiz can of rtv makes it easier. worth the money.$11 at autozone last I saw.
" When you men get home and face an anti-war protester, look him in the eye and shake his hand.
Then, wink at his girlfriend because she knows she's dating a pussy." General Tommy Franks
"Congressmen who willfuly take actions during wartime that damage morale and undermine the military are saboteurs and should be arrested, exiled or hanged".
President Abraham Lincoln
Old May 5, 2005 | 04:41 AM
Duceanahalf's Avatar
is doing your girlfriend
The standard Fel-pro gaskets that came with my rebuild kit were the right size for my RPM Air-Gap.
Old May 5, 2005 | 06:17 AM
racingtheburg's Avatar
Pro 5oh
A)I would scuff up the block and intake front and back where you would put rtv...2nd use the coll blue stuff for water pumps ect....after that I would use 1-4 thick like stated.
B)If you dont want to use rtv I would go to discount auto and they have the rubber gaskets for the front and back holds better then the cork..and I would put a little rtv on them ect. scuff both surfaces once again.
Hope this helps...
Old May 5, 2005 | 06:18 AM
Big-D-Bo's Avatar
yeah thx all, I am gonna do it today that take some pics and post them in new topic. Thx again
Derek
-Derek-
djcrx456
Jun 30, 2003 07:05 AM
juiced2ndgenteg
Jun 29, 2003 10:08 AM
stehigs321
Nov 3, 2002 04:56 PM
