Idle problem when rolling
Old Mar 26, 2005 | 11:01 AM
StuntMan's Avatar
Driver
Default Idle problem when rolling
For some reason when I am going over 5mph and I have the car in neutral it won't idle right. It bounces around between 800-1300rpm but once I am almost to a complete stop it will idle fine. This is driving me crazy trying to figure out the problem the idle air control valve seems fine and there are no codes.
If speed kills then I'm suicidal
Old Mar 26, 2005 | 12:32 PM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
ah the joys of 5.0 fuel injection. Mine did that, try cleaining the "salt and pepper" terminals behind the upper intake. Sometimes when those get dirty they can make your car surge. Your EGR can be bad, your BAP sensor could be bad, Your tps voltage could be off........ blah blah blah along with like 50 other things.
Derp!
Old Mar 26, 2005 | 01:13 PM
StuntMan's Avatar
Driver
Its a 4.6 2v. The car is a 98 GT. I checked the tps voltage already.
Old Mar 26, 2005 | 02:36 PM
91blowngt's Avatar
do you have a cold air set up on it ? have you cleaned your mass air sensor latley ?
Old Mar 26, 2005 | 02:42 PM
69Boss521's Avatar
If you have mods post them, or is it all stock?
Derp!
Old Mar 26, 2005 | 04:23 PM
StuntMan's Avatar
Driver
I have not cleaned the mass air recently.
The car has a S-trim supercharger(6psi), 24lb injectors, 87mm mass air, 70mm throttle body, chip, coil packs, headers, off-road H-pipe, mil eliminators, other than that the motor is pretty much stock
Old Mar 26, 2005 | 04:39 PM
91blowngt's Avatar
does the car idle just sitting still ? if so id have to say where ever you have your filter located needs to be covered more !
Old Mar 26, 2005 | 04:52 PM
StuntMan's Avatar
Driver
The car idle fine when it is sitting still. The filter is located in the bumper and was recently cleaned.
I am thinking maybe I should get the car tuned?
Old Mar 27, 2005 | 06:27 PM
bottlefedLX's Avatar
Don't be so angry
Absolutely get the car tuned. You may have a hole after the air meter allowing unmetered air into the engine.
John
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
MaxType 240
Nissan/Infiniti Tech
20
Apr 20, 2004 07:09 PM
NChatch
Power Adders
10
Aug 25, 2003 12:02 AM
Sangui
Mar 17, 2002 10:39 PM
CXHatchback
Dec 13, 2001 09:25 AM
