Sn95 Need Help.....
Old Dec 15, 2004 | 05:12 AM
mx-4u2nv's Avatar
Default Sn95 Need Help.....
What is the sensor called that adjust idle when there is a load put on the motor? I have replaced the Idle air motor, and the TPS. The car idles up and down betweem 700-900, when you turn the steering wheel at idle, or turn the AC on the car shuts off? Any help would be greatly appreciated!
"Been educating 4drwhore since 11/24"
Originally Posted by Na306StAnG
I only date chicks with down syndrome this way I know from day one their fucking retarded.
Old Dec 16, 2004 | 07:44 PM
mustangman98's Avatar
Mullet Powered
goto Autozone and have them scan it and they will tell you what is wrong with it, but i believe what you need is a Idle air valve.
03 Gt - SOLD!
88 LX Coupe - 308 with a few mods...
Old Dec 17, 2004 | 04:40 AM
mx-4u2nv's Avatar
Thanks, but isn't that in the IAC motor which I already replaced?
Old Dec 17, 2004 | 05:34 AM
bigB's Avatar
i eat hamburgers
Originally posted by mustangman98
goto Autozone and have them scan it.
Originally posted by Vito_Corleone I'm a ricer.
Old Dec 17, 2004 | 06:11 AM
mx-4u2nv's Avatar
Ok I get the Hint will post and let you know what they say!
Old Dec 17, 2004 | 01:08 PM
N20D5OH's Avatar
Exactly, just because you replaced the TPS doesn't mean it's adjusted correctly.
2013 Base Mustang GT - Tampa Stock
Old Dec 17, 2004 | 03:55 PM
herrcomestrouble's Avatar
+1 on the adjust TB... if its not that. Could be a MAF issue.. is the CEL on?....
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Dec 20, 2004 | 05:58 AM
bullit proof's Avatar
The tps is nonadjustable on the sn-95. It dose have a new maf. Played with the car this weekend and found a small cut in the vaccume line from the intake to the pcv. Now the car wont stall but when the a/c or heater is on it surges between 750 and 900 is that normal with an E-303?
