SN95 Wheel Bearings
Old Apr 6, 2004 | 08:14 PM
Alan's Avatar
drives euro trash
Default SN95 Wheel Bearings
I have my SN95 spindles/hubs sitting at home, and I figure now is as good a time as any to replace the wheel bearings before I install them on the SVO. I've heard the wheel bearings are entirely different than the Fox, so I'm curious as to what is different and what parts or special tools I will need to get this done.
I may also replace the studs with ARP units. I'm assuming this will be a "press out/press in" process?
Old Apr 7, 2004 | 06:32 AM
Strokd85's Avatar
Daddy-O
you need a 36mm socket though to get the bearing unit out, if you need to borrow it let me know (vs going out and buying it)..
I am your penalty.....
Old Apr 7, 2004 | 08:48 AM
Alan's Avatar
drives euro trash
Originally posted by Force Fed 23
Yeah, the SN95 cars are a pleasure to work on since they use sealed bearings on a hub. So a brake job is easy as pie, get the caliper out of the way, slide the rotor off (no more greasy wheel bearings, cotter pins, big nuts, etc) and you're done!
So is the bearing unit similar to what was used on the rear of the Focus? Can the bearings be pressed out, or (as Jeremy said) is the entire hub replaced?
Am I just being overly paranoid? Should I be okay for quite a while with the original 10-year-old bearings?
