Coil over Q...
Old Apr 1, 2004 | 10:10 AM
Modular Matt's Avatar
200 SHOT
Question Coil over Q...
I was just wondering what rate spring you drag races out there use?I bought the 175 rate spring but was told that those are really soft 2 be using on the street?.
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Old Apr 1, 2004 | 10:34 AM
superdave's Avatar
it really depends on what you like. My opinion is a 12" 250lb coil is a good all around rate. I used to have a set of 12" 350's and loved them. Right now I have 14" 175's and they are waaay to bouncy for me. When I get around to swapping K-frames again (to a PA or Griggs setup) I'll probably go back to 350's or 300's. You can get QA1 springs from Summit for like $32 a piece.
Dave
1998 GT cp (totalled, compliments of a dump truck)
1996 pony (awaiting transplant)
Old Apr 1, 2004 | 10:41 AM
200 SHOT
cool deal thanks for the info. How did the 175's do for launching on your car?i
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Old Apr 1, 2004 | 10:46 AM
superdave's Avatar
i didnt really have a before-after for it, but with the Tokico's set at "1" the front end lifted pretty fast
Dave
Old Apr 1, 2004 | 11:46 AM
200 SHOT
thats all i really needed 2 know
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
