Problems With The Brakes
Old Feb 28, 2004 | 01:30 PM
tony122's Avatar
Default Problems With The Brakes
Hey guys i have a 1987 mustang 5.0 automatic,the problem i amhaving as of now are the rear drum cylinders they were leaking n the last few days the rear brakes wornt working i put new cylinders on today both of them but their is no brake fluid coming to the cylinders the brake pedal feels jus tlike before only the front ones are working,does anyone know what it could be??any help would be greatly apreciated thanks in advance guys.
Old Feb 29, 2004 | 04:16 AM
tony122's Avatar
Thanks guys,well ok the lines coming to the rear cylinders are aluminum or sometype of mettle were do they turn rubber,these line run on top of the rear axles well i guess it must be somewere under the car then i will check that this morning thanks guys
Old Feb 29, 2004 | 01:56 PM
WHY_NOT???'s Avatar
you did bleed them right and yes rubber hose from body to caliper, make sure to keep planty of fluid in master cylinder or you will be fuct!!!!!!
2013 Ford Escape Titanium - grocery getting power
TR's Tactical Trunk Monkey Crew #001
Midgets and Beer!!!
the book of faces
