Stroking problems...
Old Dec 19, 2003 | 08:18 AM
Toma's Avatar
Ricer In Training
Default Stroking problems...
No, it's not what it sounds like. In a stroked motor would the rotating assemby be exposed to greater stress (besides compression being bumpes up)due to the fact that the piston has to travel farther. Would that have any impact on the rods, crank, piston head, rings, etc. or would it be just as reliable as the block with factory spec rotating assembly? Would a 331 be more reliable and last longer than a 347?
Just wondering...
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
Old Dec 19, 2003 | 11:17 AM
race495's Avatar
Pull Over
Go to www.corral.net and do a search, be prepared, you will be sitting in front of your computer for a few weeks.
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
Old Dec 19, 2003 | 12:11 PM
Toma's Avatar
Ricer In Training
Originally posted by Force Fed 23
The biggest factor is the rod ratio. Basically its the length of the rod compared to the stroke of the engine. The shorter the rod ratio, the more stress is put on the assembly because at BDC, the rod is almost pointing to the side of the bore. With a longer rod, the angle is alot less. The less angle, the less side stress is placed on the moving parts. This will decrease wear on the bore, piston, ring, bearings etc. I forgot what most engine builders shoot for. I believe its like 1.7:1 or so.
THANX!!!
That answered it.
