Anyone have dyno results for a stock GT 99 and up?
Old Nov 13, 2003 | 01:26 PM
RazziGT's Avatar
Phantom Stang
Question Anyone have dyno results for a stock GT 99 and up?
Hey I was wondering if any of you guys had a dyno graph or could tell me when it is a stock GT hits it's max HP before it's starts to drop? I had something that told me but can't find it online anymore. See my plan was to set my G-tech Pro to flash at me just a little after I hit the max so i can shift at a good time were i can hold onto a good amount of HP. That sound like a good idea to you all? But if anyone has a dyno graph or knows what it is let me know.
Thanks
Old Nov 17, 2003 | 07:31 PM
351coupe's Avatar
refinish artist
WHAT DO YOU SHIFT AT NOW AND WHAT GEAR DO YOU HAVE?woops
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
Old Nov 17, 2003 | 08:24 PM
RazziGT's Avatar
Phantom Stang
i shift low right now trying to keep gas in the car you know but when i push it i was shifting like right near redline but i backed it off some and it felt a little more strong when i shifted around like 4800 - 4900 maybe it's just me i don't know....my gears are 4.10 gears
- Vince
It's something like stock...
Old Nov 18, 2003 | 02:49 AM
mustangman98's Avatar
Mullet Powered
i seen this is MM&FF this month issue, they took a bone stock 01' GT with a cat-back and headers and put a new kenny bell twin screw super charger and made over 500hp on the ground with stock internals. i think it was running like 15psi. but anyways they dynoed it before hand and got like 247RWHP @ around 4,500. when they added the twin screw at 6psi it put down 357 then 9psi 398, 11psi 430, 15psi 511
03 Gt - SOLD!
88 LX Coupe - 308 with a few mods...
Old Nov 18, 2003 | 07:14 AM
RazziGT's Avatar
Phantom Stang
ok cool that i can use thanks alot. You know and i have that issue and i didn't even think to read that article again but thanks bro
- Vince
Old Nov 18, 2003 | 07:32 AM
TheShow50h's Avatar
The little 5.0 that could
I think it's a very general rule of thumb, but you should generally shift 500rpms past your peak. It depends on the car though.I shift my 5.0 at 5700rpms. I shift at 5,000 if I'm walkin away, 5700 or so if it's close. I do this because I figure every rpm is going to count with a 100,000 mile motor.
-Vince
Old Nov 18, 2003 | 08:11 AM
Modular Matt's Avatar
200 SHOT
My car is stock and i shift at 5500 5700 RPM's
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
