Hood latch adjustment
Old Sep 1, 2003 | 05:02 PM
catfish's Avatar
No Mam
Default Hood latch adjustment
I slipped the new Cobra RR hood on today just to take the car out for a drive to see if the car cools a little better with some airflow over the top of the engine. Plus, I figured, a white hood on my green Mustang should be good for another 10 or 15 hp. I had to enlarge the holes in the hinges that the studs go though. The hood gaps are nice and even at the back of the hood. As I lower the hood, the gaps look like they should remain even, but the latch pushes the hood about 3/8" to the drivers side. I end up with no gap on the drivers side and a 3/4" gap on the passenger side. The latch is forcing the hood over.
Is the latch adjustable to the left and right? I loosened the two 8mm bolts holding the latch assembly in place, but there are two locator pins that prevent left/right movement. Any suggestions?
Beer. Now there's a temporary solution. --Homer Simpson
Old Sep 1, 2003 | 08:32 PM
Goopster1's Avatar
|-Resident LT1 Killer-|
Default Re: Hood latch adjustment
what kind of hood is it?
If its a Kaenen(SP) it should be a nice fit, they have decent hoods from what I have seen, along with Cervini's.
Old Sep 2, 2003 | 06:51 PM
stangerang's Avatar
whoopdy fucking do!
the hood might be a bit small cut........... try adjusting one of the fenders ! .... easy to do.............
200 points away from a 300
Old Sep 3, 2003 | 05:45 AM
catfish's Avatar
No Mam
It's a Keanan that I bought from Joe @ Fordspeed.
Adjustment on the hood? It looks like the plate the latch catches on is pop rivited in place. I think I need to look at it again.
Dave - Not to invite myself over, but I would like to swing by for a ride in your 4 cylinder, if you have the time. Of course, I would return the favor with my anemic little ride. Maybe you could help me analyze the clutch issue I am having.
