The Ford Forum Lounge Off Topic Group for Ford Forum Members or other regulars. Keep it work safe please. No tech posts.
help
Old Apr 30, 2012 | 06:02 PM
MR. STPETERSBURG's Avatar
Default help
1996–1997 Ford Mustang, 215 hp (160 kW) and 285 lb·ft (386 N·m)
1998 Ford Mustang, 225 hp (168 kW) and 290 lb·ft (393 N·m)
1999–2004 Ford Mustang, 260 hp (194 kW) and 302 lb·ft (409 N·m)
those are the numbers for said motors all 4.6 2v
what is different while going up through the years....what did ford change in that time
Originally Posted by JH26
My neighborhood watch and I are already locked, cocked and ready to rock.
Old May 1, 2012 | 03:13 AM
Zman's Avatar
I gota Cheby
pi heads and intake came on the later years. A lot of guys will swap the pi heads and intake on the earlier 4.6's for a easy hp increase. These motors like a lot of gear also.
Only 1/4 mile track I know is Gandy Bridge
Old May 1, 2012 | 04:59 AM
thanks i appreciate it i assumed it was the head but wanted to be sure. now to find a set...
Old May 1, 2012 | 05:55 AM
after looking at the cost it will cost me about 840 for a set of new ford racing PI heads... i figure i would do that over buying a used pair($300) and then sending to the machine shop as it wont be that big of a price difference....but then i saw these.
Patriot Performance 1004R - Patriot Performance Ford Stage II Remanufactured SOHC Cylinder Heads - Overview - SummitRacing.com
thats supposed to be 40 HP over the stock pi heads? giving me about 80-90 overall. thinking of pennying up the extra cash to do that....or is my logic off or something im missing?
Old May 1, 2012 | 04:23 PM
BigDawg's Avatar
has his prioritys ef'd up
If your gonna spend the money on heads, you might as well pony up for new cams.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old May 1, 2012 | 05:49 PM
blacksheep-1's Avatar
When it gets to the handling aspects of that car, you need to call me. I pm'd you about that.
Old May 2, 2012 | 04:30 AM
i plan on it. and yes if im gonna do the heads theres no point in not doing cams. blacksheep i will be doing that asap. im picking up new wheels and tires and then i will address susepension. not trying to go faster then stock with suspension now.
