Greetings & Salutations
Good Morning TR:
A quick Friday morning note to introduce myself and say "HI". Thanks for having me and my race prepped BMW M3. Hopefully, I can be of some use in here.
Mark "Feff" Pfeffer
Mark "Feff" Pfeffer
That's great!
Wow!
Feff,
How about some details about the M3?
Wow!
Feff,
Turner Motorsports built M3 with a lot of goodies. Just needs a better driver. Here's a shot at Road America.
Feff
[ATTACH=CONFIG]206679[/ATTACH]
Feff
MVP Track Time
MVP Track Time
Thanks for the pic.
Car looks clean.
If you want to see a few member rides, or post some more about your own car,
here is a forum:
https://www.tamparacing.com/forums/members-rides/
And if you did some things to make it a fast car, we definitely want to know! lol
Here in flatland Florida, we would like to know about Road America, too.
How big? What kinds of curves? When do they race? I've heard the name, What is it near?
Car looks clean.
here is a forum:
If that's a go-pro in there, do you have some video?
-Bob
-Bob
2001 BMW E46M3: Built by Turner Motorsports
FullTurner Motorsports roll cage
S54 3.2Liter in-line 6 cylinder (approximately 10 hours on engine rebuild)
C&RAluminum radiator (New October 2016)
SPALelectric fan with manual dash switch
Turner Motorsportsunderdrive pulleys
VorschlagCompetition polyurethane engine and transmission mounts (October 2016)
BeisenVANOS upgrade
Fluidyneoil cooler with braided steel oil lines
JB Racinglightened aluminum flywheel
Sachsclutch (new with engine rebuild)
Bimmerworldfuel starvation kit
EPICstepped headers
SupersprintStepped section-1 straight pipe
Supersprintsection-2 straight pipe
Supersprintrace muffler
Seiboncarbon fiber
CobraSuzuka carbon fiber racing seat on VAC adjustable seat mounts
PegasusRacing adjustable seat back brace
Schroth6-point HANS compatible harness (new April 2016)
SparcoFire Warrior fire suppression system
Brembo GT4-Piston Brakes with braided steel brake lines
Bimmerworldcarbon fiber brake cooling ducts
CAEmanual shifter (Shifts like a fine bolt-action rifle)
JRZ 2-Wayadjustable shocks (Rebuilt October 2016)
GroundControl front & rear adjustable sway bars
GroundControl Race camber-caster plates
RogueEngineering RaceBrace front strut brace
TurnerMotorsports aluminum rear subframe mount bushings
TurnerMotorsports aluminum monoball rear trailing arm bushings
BimmerworldTrackCAB solid front control arm mounts
EibachSprings
C-Type (2 sets)
Front:18 X 9.5
Rear:18 X 10
GT X (1 set)
Front: 18 X 9.5
Rear: 18 X 9.5
Brand newHoosier R7 slicks on two sets and Nitto NT01 (one track weekend) on other set
Turner Motorsportswheel studs
Polycarbonaterear window and rear side windows
Longacre17” convex rear-view mirror
Compositealuminum front splitter
AIM Solo DLdata system
Car Weight:2,947 pounds with full fuel load and no driver
- Schrick DLC-Coated rocker arms
- Supertech racing valve springs and retainers
- ARP head studs
- ARP main studs and connecting rod bolts
- Calico Coatings main bearings
- Bimmerworld WPC Treatment rod bearing upgrade kit
- 345 horsepower at rear wheels (Approximately 401HP at crank)
- 251 foot pounds of torque at rear wheels
BeisenVANOS upgrade
EPICstepped headers
Seiboncarbon fiber
- Hood
- Front fenders
- Trunk lid
- Front: 355mm
- Rear: 345mm
EibachSprings
- Front: 700 pound
- Rear: 750 pound
C-Type (2 sets)
Front:18 X 9.5
Rear:18 X 10
GT X (1 set)
Front: 18 X 9.5
Rear: 18 X 9.5
MVP Track Time
MVP Track Time
I like the weight saving items.
I had noticed some low circles on the rear window and I wondered if they were to let the air out.
The carbon fiber is not easy to see.
Are you one of the people who puts on Road Atlanta and Daytona in November and December?
Yes, I am MVP Track Time (MVP Track Time) and we will be hosting a track event at Daytona December 8-10, 2017.
Feff
Feff,
I opened a shop forum for MVP, if you want to post a few press releases here:
https://www.tamparacing.com/forums/t...rack-time.html
or post whatever you want to promote....
The small circles on the rear and side windows are to relieve air pressure, keeping the windows attached to the car. All the carbon fiber (hood, front fenders and trunk) are painted to match the car.
Feff
Feff
Hello to everyone here.
The site suggested I introduce myself, so here it goes....
I'm Elton Hammonds and asked to join because I drive a 2015 Subaru WRX STi Launch Edition.
It's mostly stock and will likely remain mostly so since I'm not the racing type, but I'm intrested in tweeking and peaking it a little...
I've just ordered an Ingen Evolution air box and am eyeballing a couple axel back muffler delete options.
I've already installed the Whiteline rear bushings and have the RSE Yellow springs.
What I'm trying to figure out is if someone can tune my car for the new airbox and muffler delete without my having to buy a Cobb Accessport. (they aren't cheap...)
