Drag Racing Don't like turns? Tech talk about drag racing and drag event discussions here
Suspension gods (sub 1.6's) Need some help here
Old Feb 11, 2006 | 11:18 AM
bitemark46's Avatar
Got traction?
Default Suspension gods (sub 1.6's) Need some help here
Read this thread. Squat is good or not good? -Mark
https://www.tamparacing.com/forums/f...ml#post2950319
98' cobra
Old Feb 12, 2006 | 06:07 PM
10secgoal's Avatar
Not good. I knocked off .02 (60 ft) on average when I got it to stop. Anything that is not moving the car forward is a waste, squatting, lifting the front end. There are compromises though. Some need the weight transfer to get traction. But if you are dead hooking, it would be a complete waste to put in 90/10's. Your 60 would be worse after that.
It is also possible to get your front end to rise too fast.
Torque is something you build for,HP is something you lie to your friends about. And just because you drive it around the block," DOESN"T MAKE IT A STREET CAR."
Old Feb 12, 2006 | 07:20 PM
Jap's Avatar
Jap
VTEC Out
As I stated in there its just a loss of foward momentum ...
A hard hooking car will just slightly rotate lift the fronts and carry themm through the 60 or past depending on power
Hondata saves lives
Old Feb 12, 2006 | 08:47 PM
Little Nicky's Avatar
1140cc's of power
glad you posted it here.
Facebook
05 zx10r with a lot done still never will be stretched
Old Feb 14, 2006 | 09:04 AM
01_Ram-Air's Avatar
10s are next...
You're right Mark, you don't want squat, you want the "tires" to take the hit.
2001 Pontiac Trans Am Ram-Air, Red, 3 speed
Old Feb 18, 2006 | 07:01 AM
evocrazy1's Avatar
well, when you can only get so much traction from small tires you might want it to squat. i run 26's and i need it to squat a lil to get traction, and specially when i'm on dr's
ASKED TO BE BANNED
