chassis tech help
Resident Ginger Kid...
on
chassis tech help
Well this Friday will be my first night back out in almost 2 months after I blew my motor. I had a 305 LG4 in the car with a cam and mostly stock pushing about 180hp to now having a fully built 355 pushing out about 410-430hp. I scaled my car yesterday and need to know really where to go from here and how it sits right now. This is the side of chassis tech I dont quite know to well.
---------1780lb 52%
----| LF 1000 ---- RF780
53%| -----46% cross --------3430lb total
--------| 1650lb 48%
----| LR 810 ----- RR 840
---------1780lb 52%
on
Ride heights I do not have right now, car is currently strapped to the trailer for friday out in my barn. But I will get the ride heights, If I was to guess I would say the front is 3.5in from the ground and the rear is 5in. Its got a nasty rake going since I removed the 2in lowering blocks from the rear (which also improved handling) as this car was previously a Asphalt car. I also need to get the numbers from the caster, camber and toe. I want to raise it up as early in the night im plowing dirt before the track gets packed in, But dont want to change the geometry yet and risk throwing what handling it does have out the window.
on
my son runs on dirt with a previous asphault car and i debated removing the lowering blocks in the rear , to see if it would improve anything, im having a problem with the engine popping, it revs great it idles great, when you put it on the track it runs great on pace laps but when you drop the hammer it starts popping and wont make it over 4000 rpm, ive checked the fuel psi, floats in carb, power valve, plugs. wires, timing, i just dont know what im missing.
Stealth Mode
06-24-2016 03:08 AM
sullivanracing06
For Sale/WTB Nissan
4
06-27-2011 04:24 PM
shinmei2006
Nissan/Infiniti Tech
97
12-19-2008 07:22 AM
PerformanceOutlet
Chassis & Suspension Tech
10-24-2008 01:34 PM
Cronic
08-08-2003 06:33 AM
