Now I know this Stock Turbo Just cant move any more air!
Old Apr 12, 2003 | 11:58 AM
4sfed 4's Avatar
4SFED4
Default Now I know this Stock Turbo Just cant move any more air!
I redynoed the R/T after putting in the new intercooler and I think I can now say that I have pushed the stock turbo as far as it is going to go. The poor little fella just cant move any more air than this!
The car is a 1991 Spirit R/T with stock computer, stock turbo, RR 3 core IC, 3" catless exhaust with Ultraflo muffler, +40's, and an adjustable FPR set at 35 psi base pressure vacuum line connected (about 42 psi with the vac line disconnected.)
The fuel curve is crap and the low end needs lots of work (way overfueled), but its the best I could do with just base pressure adjustments to work with and using the stock cal.
Peak boost on this run was 25 psi around peak torque wih boost pressure rapidly dropping to just a smidge under 15 psi at the top of the run as the turbo huffed and puffed in desparation! The test was made in 4th gear and with 93 octane pump gas.
Larry
2002 MB C320 Sport Wagon 15.4@91
2002 Dodge Neon SE
1991 Dodge Spirit R/T-12.3@117 (at 368 whp) Now 500 whp / 514 ft lb on pump gas
Old Apr 12, 2003 | 12:46 PM
Grease's Avatar
Old Man With Fast Wheels
Looks good up to 4200rpm then it falls bad..
Hope you get it worked out....
Old Apr 12, 2003 | 12:52 PM
4sfed 4's Avatar
4SFED4
It drops off like that becuase the turbo cant keep up with the airflow demands! A T3/T4 will solve the problem.
Larry
2002 Dodge Neon SE
Old Apr 12, 2003 | 12:57 PM
mpbiv's Avatar
Rod Bearing Eater
Your just running +40's and a FPR for fuel control with the MAP tricked? Sounds kind of hard to tune like that. Nice work though
Now you need to update your sig
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Apr 12, 2003 | 01:03 PM
4sfed 4's Avatar
4SFED4
Yep...thats it. +40's, a Rick Diogo AFRP and an adjustable zener diode on the MAP sensor that I made myself for $4 with parts from Radio Shack! Yes...it is harder to tune like that! But, any yahoo can just send out PayPal payments to vendors and order parts! I like to see what I can do to max things out first!
On that note.....I believe that my R/T owns the highest output of any stock turboed Dodge! At least that I know of!
Thanks for reminding me!
Larry
2002 Dodge Neon SE
Old Apr 12, 2003 | 02:23 PM
emodsm's Avatar
red ass
301 hp!! 388 tq!! damn larry!! Great job!! any updates on frankenstien?
eric.
Build your car for YOU, not for the fame and glory. Fame and glory fade with time but YOU will be around as long as you live.
Old Apr 12, 2003 | 03:37 PM
4sfed 4's Avatar
4SFED4
Frankie has been playing second fiddle lately I must confess!
Larry
2002 Dodge Neon SE
Old Apr 14, 2003 | 08:31 AM
Clint's Avatar
keyboard hardass
got Torque Steer?
Offroading Spots near Tampa
Green markers = Pay spots
Blue markers = safe free spots
Red markers = not so safe free spots (possible trespass issues)
