Car won't start...push button...fuses....new battery...
Old Jul 24, 2019 | 05:46 AM
Default Car won't start...push button...fuses....new battery...
Picked up a wrecked 2013 Challenger couple days ago. Soft hit on the left front. Key fob will unlock the doors, set the alarm and turn it off. Panic works. But it won't start the car. Get in and hold the brake and push the button, the gauges all do their thing and then nothing. Dash says Push and hold brake and push start button. I can hear the fuel pump work, but it does not turn over, or even try. I have checked fuses. I have bypassed the starter relay and it does turn over just fine, but will not start. I have swapped in a brand new battery that was all charges up. Any help would be appreciated!
In the engine compartment fuse box there are several fuses & relays that can affect start/run.
Fuse #37: engine controller
Relay #59: ignition run/start
Relay #63: automatic shutdown (ASD)
The fuse box in the trunk has relay #1; ignition run
Apr 4, 2019 09:08 PM
JoKiE crx4294
Jan 19, 2009 04:31 AM
omgosh
Dec 12, 2008 06:48 AM
Grizzly0205
Jan 6, 2007 11:00 PM
Dave6699
Aug 3, 2005 05:00 PM
