2009 Police Charger - Codes AntiLock Brakes My brakes are locked and sometimes they
My brakes are locked and sometimes they are not.
Here are the codes:
U0121 - Lost Communication with AntiLock Brake Control Module
U140C - Implausible Right Rear Wheel Speed Signal Received
U140B - Implausible Left Rear Wheel Speed Signal Received
P0501 - Vehicle Speed Sensor A Range / Performance
C2200 - Antilock Brake Module Internal
C121A - Steering Angle Sensor Not Initialized
C1044 - Right Rear Tone Wheel Performance
C2116 - AntiLock Brake System Pump Motor Supply Low Voltage
C1032 - Right Rear Wheel Speed Sensor Signal Erratic Performance
C1027 - Left Rear Speed Sensor Signal Erratic Performance
C2100 - Battery Voltage Low
C2101 - Battery Voltage High
Here are the codes:
With that many codes it could very well be the ABS module. It could also be a wiring harness/connector problem (circuit shorted to voltage, ground or open) or a open ground problem. You may want to check the wiring harness and ground connections for corrosion, damage, etc... before replacing the ABS module.
05-11-2017 03:35 AM
CreAsiaNDoriEj6
05-23-2011 07:57 AM
BAMF
13
02-12-2005 08:47 AM
