2015 Dodge Charger SXT AWD transmission fluid change?
AUDITORIE1Junior Member Join Date: Apr 2019Posts: 1Feedback Score: 0 reviews2015 Dodge Charger SXT AWD transmission fluid change?Hello my name's Daniel I recently bought a 2015 Dodge Charger from local dealership here in North Dakota and it's practically brand new got it where it had only around 23,780 mi on it and I looked at the manual for when it came to getting the transmission fluid changed but I'm just curious if anyone can tell me when I should get my transmission fluid changed? I've never owned a Dodge Charger ever so this is my first and I've only put about 1,500 miles on it.
Stevens12Senior Member
https://www.chargerforums.com/forums...tar54979_8.gif Join Date: Mar 2012Location: Altoona, PaPosts: 4,169At only 23.7k mileage, I don't think I'd change it. It's not cheap. The filter is built into the pan, so you have to replace the entire pan, then the fluid from the dealer is expensive. If you paid the dealer to do it, I've seen people hit with $700 bill for that. I believe the owners manual states 100k before "recommended" change. I'm running mine till 75k then doing it myself for my wifes 2015 SXT awd, and while I'm at it, doing the diff fluids too at that time. |
Two different ways to do this based on what we have seen with the factory ZF fluids. Either change it at 30,000 miles by simply doing a pan drain and then refill and take the fluid out another 35,000-40,000 more miles and then change it at 70k miles with the filtran pan at that point pushing it to the limit of the filter.
Or just drive to 50,000 miles and change it along with the filtran at that time. The fluid comes out black and gritty at 50k miles and there is no way that I would recommend going 100,000 miles on this fluid! If the vehicle is under warranty then we recommend an OEM Chrysler pan which we provide at 10% over cost and include the QuantumBlue ZF 8 Speed Replacement Racing ATF at $14.95 per quart and $119.60 for 2 gallons. Remember that the 8HP70 filtran is $307.00 from the dealership as of today and their fluid is $33.50 to $43.25 per quart. Here is more information on it but you really have two choices to protect this unit: https://www.chargerforums.com/forums...d.php?t=303257 For reference, this is what ZF recommends: |
1 Attachment(s)
Attachment 61264 |
1 Attachment(s)
4 Attachment(s)
As far as the pans go, you HAVE to get the right flow characteristics and fluid volume right or you will cavitate the transmission......but hey, you bought an aftermarket pan for $60.00 less....and now you have a $4,000.00 bill to deal with but you saved initially......foolish. Get the correct pan.....and we provide it for all our customers!
Aftermarket vs. OEM Aftermarket is on the left and the OEM is on the right. Attachment 61259 OEM again Attachment 61260 OEM Again Attachment 61261 Aftermarket: Attachment 61262 |
1 Attachment(s)
Oh, and by the way, you can't reuse the bolts and the aftermarket doesn't come with any!
Attachment 61258 |
The aftermarket pan comes with the bolts.
https://www.dormanproducts.com/p-125155-265-850.aspx The MOPAR filter is available online at Rockauto for an additional $60 if people would prefer that route. They also sell the OEM Mopar/ZF fluid for $25/qt. I'm simply providing additional alternatives. |
https://static.dormanproducts.com/im...65-850-009.JPG
https://static.dormanproducts.com/im...65-850-007.JPGhttps://static.dormanproducts.com/im...E_Sol_logo.jpg 265-850SHARE:Transmission Pan With Drain Plug, Gasket And BoltsApplication Summary: Chrysler 2016-13, Dodge 2018-14, Jeep 2018-14, Ram 2018-13Product DescriptionThis transmission oil pan has been reengineered to simplify service. The original trans pan uses an integrated filter that requires replacing the entire assembly to service. This pan is designed with a replaceable filter to simplify future servicing.
Detailed ApplicationsProduct SpecificationsBolt Hole Quantity:13Color/Finish:Black Depth:2.2 In. Dipstick Port:No Drain Plug Included:Yes Drain Plug Type:Threaded Drain Thread Diameter:M24 X 1 mm Gasket Configuration:One Piece Gasket or Seal Included:Yes Grade Type:Regular Installation Hardware Included:Yes Length (In):19 In. Mount Hole Diameter:8 mm Oil Cooler Return Fitting:No Package Contents:Transmission Pan Package Quantity:1 Packaging Type:Box Transmission Filter Extension Included:No Transmission Filter Included:Yes Transmission Pan Capacity Increase (Qts):0 Transmission Pan Material:Plastic Transmission Pan Style/Type:Standard Transmission Plug Included:Yes Transmission Temperature Sending Bung Included:No Transmission Type:Automatic Width (in):11 In. OE NumbersDIRECT OE CROSS68225344AACHRYSLER 68233701AACHRYSLER Technical InformationAdditional ResourcesTechnical Support AvailableEmail: techsupport@dormanproducts.comWhere To BuyBelow you can search and find your area locations that sell Dorman Products. Please be sure to call the location of your choice to verify this item is in stock and available. |
