Throttle Calibration- Relearn? Car Feels Different
Old Apr 4, 2019 | 01:34 PM
Default Throttle Calibration- Relearn? Car Feels Different
82,190 views813 36 Share
SaveR/T LifePublished on Jun 24, 2017Let me know if you try it. After researching throttle relearn & calibration I may have stumbled onto something here. In the Charger/Challenger this method has resulted in the air intake being a little louder & my estimated gas mileage going up. There had to have been a throttle calibration or relearn in the 2015 2016 2017 Charger RT.
Old Apr 4, 2019 | 01:36 PM
Jason S I saw this video and just tried it on my 18 DD R/T after reading some other forums as well. I turned it to run, waited for dash lights to turn off other than check engine. I started pushing the pedal slow and the engine light started flashing, which was a good sign. Held the pedal for 20 seconds at the floor, brought it up and turned the car off. Then I turned it back on. This definitely worked. The car acts like I’m pushing the pedal down harder than I actually am and seems to shift a bit later. Almost like a hybrid sport mode, since I’m still in ECO mode while driving around normally. Thanks for the heads up that something like this existed. I just hope the computer doesn’t automatically reset it to factory every time I drive.
Old Apr 4, 2019 | 01:40 PM
He says it works.....2006 -2017.
Old Apr 6, 2019 | 02:46 PM
Resetting throttle position:
Try resetting the throttle position first: turn ignition to run (foot off the brake so the engine doesn't start) when the chimes and dash lights stop their dance, press the gas pedal all the way to the floor and let it back up again within 10 seconds (5 seconds is better) then turn the ignition off. This re calibrates the pedal to the throttle body (if you press the pedal down three times quickly it also resets the oil change light).
There is a TSB to re-flash the PCM when you get that particular code..might solve your problem (this is for the 2011 models, but yours could still have a PCM problem)
https://www.autocodes.com/uploads/ch...SB_1801811.pdf
Just found this on a Jeep site..basically says that since the oil pump will not switch into high pressure mode, the RPM is limited to 3500 rpm--you may need a new oil pump..time to take it to the dealer for confirmation.
https://www.jk-forum.com/forums/stoc...-3-6-a-310938/
Reset it then go to an autozone and have them read the computer for any fault codes..it is beginning to look like you may need a new gas pedal assembly (it has a potentiometer that sends a signal to the throttle body telling it how much to open) or a new throttle body... one of the two is not working nicely with the other.
Part is called the "accelerator pedal travel sensor" which is the sensor and padeal all in one:
https://www.stevewhiteparts.com/oem-...Y2LWdhcw%3D%3D
Sep 26, 2019 09:37 PM
Apr 4, 2019 01:29 PM
Newguy07
Jun 22, 2008 07:03 PM
oldandbusted
Feb 17, 2005 04:58 PM
