Dodge Charger Check Engine light codes, etc
Old 03-20-2019, 09:28 AM
Default Dodge Charger Check Engine light codes, etc
Originally Posted by smatloff
Hi All,
My 2010 Charger 5.7 Police Package is giving me a P1524 code. I'm seeing different answers to what it is so thought this would be the right place to ask what to look at to fix it.
Thanks,
Steve
Steve,
it is the Oil Pressure Out Of Range Camshaft Advance / Retard Disable
Low engine oil level
Faulty Oil Pressure Sensor
Oil Pressure Sensor harness is open or shorted
Oil Pressure Sensor circuit poor electrical connection
Regards,
Brian
Old 03-25-2019, 10:06 PM
First check your oil level & oil condition. This code can get logged if the oil level is low or the oil & filter need to be changed (use 5W20 oil).
For the Variable Camshaft Timing (VCT) to enable, the oil pressure has to be approximately 42 psi. For the VCT to remain enabled the engine oil pressure can not drop below 31 psi.
The onboard diagnostics monitor for this condition when the engine running, RPM is greater than or equal to 1100 and the oil temperature is less than or equal to 212°F.
The onboard diagnostics will set P1524if the engine oil pressure never reaches the calibrated specification required for VCT activation.
Location of the oil pressure sensor is under the alternator. Couldn't find a Dodge Charger video but the 5.7L in a Durango is close enough.
2011 Dodge Durango 5 7L Oil Pressure Sensor
33 views2 0 Share
SaveThe JAG FamilyPublished on Feb 10, 2019I made this video to help other replace their Oil pressure sensor on a 2011 Dodge Durango 5.7L
cutty2fast
02-09-2008 08:16 PM
radicallow
01-26-2008 07:13 PM
mafro
11-22-2005 03:54 PM
alri0085
03-12-2005 04:24 PM
QuickSC2 3HT
01-04-2004 07:48 PM
Quick Reply: Dodge Charger Check Engine light codes, etc
