Installing 2015-2019 Charger, Hellcat, Demon, etc. differential Brace
Speedy's Garage Hellcat Per4mance Development Diff Brace8,126 views SaveShop "rear differential brace hellcat"https://yt3.ggpht.com/a-/AN66SAw-n8b...ffffff-rj-k-no Published on Jul 29, 2017 |
Differential Brace for Hellcat Challenger and Charger. Plus First Car Show1,060 views Save Help me reach 100K subscribers! In this video I install a Per4mance Development differential brace onto my Hellcat Challenger. This will also fit your Hellcat Charger and possibly other SRT cars. I also take the Hellcat to its first Car Show.
This installation starts at about 4 min and is Demon specific
A Demon Has Fallen! Dodge Demon Self Defense54,300 views Save After hearing about the Dodge Demon that broke its differential I decided to exercise some self defense for my Demon. I went and got a differential brace installed with my good friend Billy who installed the diff brace on my Dodge Hellcat. The differential brace was made by Per4mance Development, who make the best diff braces for modern mopars (Challengers and Chargers). PER4MANCE DEVELOPMENT
Product review Differential Brace
hellcat rear diff brace review2,126 views SaveShop "hellcat differential brace" https://yt3.ggpht.com/a-/AN66SAyse6E...ffffff-rj-k-no Published on Dec 18, 2017 |
Another brand........
2015-2019 Charger Differential Brace by BWoody*Anodized Finish Option Raw / Aluminum FinishRed Anodized, Add $10.00Blue Anodized, Add $10.00Gold Anodized, Add $10.00Black Anodized, Add $10.00 Base Price: $279.99Customized Price: $279.99 Please select the available options below.Options with an (*) are required. Once you have filled in all the required options and pressed the Update Options button you will be able to add this item into your shopping cart.
Due to high demand, orders may take 5-10 days to ship.Use this brace to help relieve differential breaking stress loads under heavy throttle for your Hellcat or Demon.Hellcat Challenger, Charger, and Demon rear differential braces. Shown here is all of the hardware and components needed to install your differential brace. All that is required for the 2015 and 2016 models are the two 8mm bolts without the nuts to bolt it to the crossmember.The 2017 -2018 Hellcat Challenger, Charger, and Demon do not have nuts inside the crossmember so TBA has made an easily adaptable nut for you to slide through the rectangular slot to easily line up the 8mm provided hardware.For the 2015 and 2016 Hellcat models just simply install the two 8mm hex nuts with a 5mm allen wrench and torque them to 20 foot pounds. The two new rear differential bolts require a 12mm allen wrench and need to be torqued to 90 foot pounds. Related Products: There are no related products |
2015-2019 Charger Differential Brace by BWoody |
Modern Mopar Differential BraceABOUT USThe patented design of the Per4Mance Development modern Mopar IRS rear differential brace help prevents differential case failures that have been occurring with modified 2015 and newer Challengers and Chargers.EASY INSTALLATION |
