DIY How to list of fuses
Old Sep 6, 2018 | 09:20 PM
Default DIY How to list of fuses
FUSES
Front Power Distribution Center (2006-2007) Diagram
#1 - 20A - yellow - left high beam headlight
#2 - 20A - yellow - right high beam headlight
#3 - 15A - dk blue - power adjustable pedals
#4 - 20A - yellow - horn
#5 - 25A - clear - headlamp washer (300 only)
#6 - 15A - dk blue - Front Control Module (FCM)
#7 - 20A - yellow - Fog lights
#8 - 15A - dk blue - parking lamps
#9 - 15A - dk blue - non-ABS brakes
#10 - 5A - orange - starter
#11 - 20A - yellow - Auto Shutdown/Powertrain Control Module (PCM) --- pull this fuse for 30 seconds to clear TCM adaptives
#12 - (empty)
#13 - (empty)
#14 - 25A - clear - Powertrain Control Module (PCM)
#15 - 20A - yellow - fuel injectors, ignition coils
#16 - 15A - dk blue - Powertrain Control Module (PCM)
#17 - 30A - pink - Antilock Brake Systm (ABS) valves
#18 - 30A - pink - windshield wiper/washer
#19 - 50A - red - Radiator fan
#20 - 20A - lt blue - starter
#21 - 50A - red - ABS pump motor
#22 - 40A - green - Radiator Fan high/low
#23 - 50A - red - HID lights (300 only)
#24 - 60A - ??? - Radiator fan
#25 - 30A - pink - Lighting Left High Beam/Right Low Beam
#26 - 20A - lt blue - transmission
#27 - 30A - pink - Lighting Left Low Beam/Right High Beam
Rear Power Distribution Center (2006-2007) Picture Diagram Diagram (cover)
#1 - 60A - clear - Ignition off draw (IOD)
#2 - 40A - green - Battery
#3 - (empty)
#4 - 40A - green - Battery
#5 - 30A - pink - Heated seat/steering column
#6 - 20A - yellow - fuel pump
#7 - (empty)
#8 - 15A - dk blue - Ignition start/run - start
#9 - 20A - yellow - Center console power outlet
#10 - 10A - red - rear fog lamp (not on Chargers)
#11 - 25A - silver circuit breaker - memory module/door locks
#12 - 25A - silver circuit breaker - passenger power seat
#13 - 30A - silver circuit breaker - door module/run/acc/delay
#14 - 10A - red - sentry key/remote keyless entry/cluster
#15 - 20A - yellow - brake light 5.7L (not on all Chargers)
#16 - 20A - yellow - rear power outlet (Magnum only)
#17 - dome lights, HVAC backlight, trunk release --- Note: service manual is incorrect - https://www.chargerforums.com/forums/....php?p=2113897
#18 - 20A - yellow - selectable power outlet (cigarette lighter) (2 positions: always on, on with ignition)
#19 - 10A - red - stop lamp
#20 - 20A - yellow - rear wiper Magnum only)
#21 - relay - run
#22 - relay - rear window defogger
#23 - relay - accessory delay
#24 - relay - transmission (NAG1)
#25 - (empty) - can hold relay - fog lamp (rear) for exports
#26 - relay - rear wiper (Magnum only)
#27 - 10A - red - airbag/occupant classification module
#28 - 10A - red - curtain airbag (optional)
#29 - 5A - orange - Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
#30 - 10A - red - Steering Column Module/Power Mirrors (optional)
#31 - (diode)
#32 - (diode)
#33 - (zener diode) - clamps voltage for various modules powered off fuses 5 and 30
#34 - (empty)
#35 - 5A - orange - Power Antenna/Garage Door Opener/Ignition Delay
#36 - 20A - yellow - Radio/Navigation
#37 - 15A - dk blue - Transmission
#38 - 5A - orange - Analog Clock/Garage Door Opener/trunk light
#39 - 10A - red - Heater mirror
#40 - 5A - orange - Power mirror
#41 - 10A - red - Climate Control Module/Headlamp Leveling (optional) /Rear Park Assist (optional) /Tire Pressure Monitoring (optional)
#42 - 30A - pink - Automatic Temperature Control (ATC) Blower Motor
#43 - 30A - pink - rear defroster
#44 - 20A - lt blue - Audio amplifier, Sunroof
Front Power Distribution Center (2008-2010)
#1 - 15A - Blue- Washer Motor
#2 - 25A - Neutral - Powertrain Control Module (PCM) --- pull this fuse for 30 seconds to clear TCM adaptives
#3 - 25A - Neutral - Ignition Run/Start
#4 - 25A - Neutral - Alternator/EGR Solenoid
#5 - (empty)
#6 - 25A - Neutral - Ignition Coils/Injectors/Short Runner Valve
#7 - (empty)
#8 - 25A - Neutral - Starter
#9 - (empty)
#10 - 30A - Pink - Windshield Wiper
#11 - 30A - Pink - Anti-lock Brakes System (ABS) Valves
#12 - 40A - Green - Radiator Fan
#13 - 50A - Red - Anti-lock Brakes System (ABS) Pump Motor
#14 - 60A - Yellow - Radiator Fan
#15 - 50A - Red - Radiator Fan
#16 - (empty)
#17 - (empty)
#18 - (empty)
#19 - (empty)
#20 - (empty)
#21 - (empty)
#22 - (empty)
Rear Power Distribution (2008-2010)
#1 - 60A - Yellow - Ignition Off Draw (IOD)
#2 - 40A - Green - Integrated Power Module (IPM)
#3 - (empty)
#4 - 40A - Green - Integrated Power Module (IPM)
#5 - 30A - Pink - Heated Seats
#6 - 20A - Yellow - Fuel Pump
#7 - (empty)
#8 - 15A - Blue - Diagnostic Link Connector (DLC)/Wireless Control Module (WCM)/Wireless Ignition Node (WIN)
#9 - 20A - Yellow - Power Outlet
#10 - (empty)
#11 - (circuit breaker)
#12 - (circuit breaker)
#13 - (circuit breaker)
#14 - 10A - Red - AC Heater Control/Cluster/Security Module
#15 - 20A - Yellow - Trailer Tow Brake Module
#16 - (empty)
#17 - 20A - Yellow - Cluster
#18 - 20A - Yellow - Selectable Power Outlet
#19 - 10A - Red - Stop Lights
#20 - (empty)
#21 - (empty)
#22 - (empty)
#23 - (empty)
#24 - (empty)
#25 - (empty)
#26 - (empty)
#27 - 10A - Red - Occupant Restraint Controller (ORC)
#28 - 10A - Red - Ignition Run/AC Heater Control/Headlights/Occupant Restraint Controller (ORC)
#29 - 5A - Orange - Cluster/Electronic Stability Program (ESP) /Powertrain Control Module (PCM)/Stop Light Switch
#30 - 10A - Red - Door Modules/Power Mirrors/Steering Control Module (SCM)
#31 - (empty)
#32 - (empty)
#33 - (empty)
#34 - (empty)
#35 - 5A - Orange - Antenna Module/Power Mirrors
#36 - 20A - Yellow - Hands Free Phone/Video Monitor/Radio
#37 - 15A - Blue - Transmission
#38 - 10A - Red - Cargo Light/Satellite Receiver (SDARS) Video/Vehicle Information Module
#39 - 10A - Red - Heated Mirrors
#40 - 5A - Orange - Auto Inside Rearview Mirror/Heated Seats/Switch Bank
#41 - 10A - Red - AC Heater Control/Headlights/Tire Pressure Monitoring
#42 - 30A - Pink - Front Blower Motor
#43 - 30A - Pink - Rear Window Defroster
#44 - 20A - Blue - Amplifier/Sunroof
Old Sep 6, 2018 | 09:21 PM
Front Power Distribution Center (2011-2014)
#1 - (empty)
#2 - 40A - Green - Radiator Fan #1
#3 - 50A - Red - Power Steering #1
#4 - 30A - Pink - Starter
#5 - 40A - Green - Anti-lock brakes --- Pull this fuse to disable ESP/ABS
#6 - (empty)
#7 - (empty)
#8 - (empty)
#9 - 20A - Yellow - All-wheel drive module (if equipped)
#10 - 10A - Red - Security
#11 - 20A - Yellow - Horns
#12 - 10A - Red - Air conditioning clutch
#13 - (empty)
#14 - 25A - Neutral - Anti-lock brakes
#15 - 25A - Neutral - Transmission
#16 - (empty)
#18 - 50A - Red - Radiator Fan #2
#19 - 50A - Red - Power Steering #2
#20 - 30A - Pink - Wiper Motor
#21 - 30A - Pink - Headlamp washers
#22 - (empty)
#23 - (empty)
#24 - (empty)
#28 - 25A - Neutral - Fuel Pump
#29 - 15A - Blue - Transmission Shifter
#30 - (empty)
#31 - 25A - Neutral - Engine Module
#32 - (empty)
#33 - (empty)
#34 - 25A - Neutral - Powertrain #1
#35 - 20A - Yellow - Powertrain #2
#36 - 10A - Red - Anti-lock brake module
#37 - 10A - Red - Engine controller/radiator fan relays
#38 - 10A - Red - Airbag module
#39 - 10A - Red - Power steering module/AC Clutch relay
#48 - 10A - Red - AWD Module/Front axle disconnect (if equipped)
#49 - (empty)
#50 - (empty)
#51 - 20A - Yellow - Vacuum pump
#52 - (empty)
#53 - (empty)
Rear Power Distribution (2011-2014)
#2 - 60A - Yellow - Front PDC Feed #1
#3 - (empty)
#4 - 60A - Yellow - Front PDC Feed #2
#5 - 30A - Pink - Sunroof
#6 - 40A - Green - Exterior Lighting #1
#7 - 40A - Green - Exterior Lighting #2
#8 - 30A - Pink - Interior lighting/washer pump
#9 - 30A - Pink - Power locks
#10 - 30A - Pink - Driver door
#11 - 30A - Pink - Passenger Door
#12 - 20A - Yellow - Cigar lighters/Instrument panel & power outlet console rear (2 positions: always on, on with ignition)
#15 - 40A - Green - HVAC blower
#16 - (empty)
#17 - (empty)
#18 - (empty)
#19 - (empty)
#20 - (empty)
#21 - (empty)
#22 - (empty)
#23 - 10A - Red - Fuel Door/diagnostic port
#24 - 15A - Blue - Radio Screen
#25 - 10A - Red - Tire Pressure Monitor
#26 - (empty)
#27 - 25A - Neutral - Amplifier
#31 - 25A - Neutral - Power Seats
#32 - 15A - Blue - HVAC module/Cluster
#33 - 15A - Blue - Ignition switch/Wireless module
#34 - 10A - Red - Steering Column Module/clock
#35 - 10A - Red - Battery sensor
#36 - (empty)
#37 - 15A - Blue - Radio
#38 - 20A - Yellow - Power outlet inside arm rest
#40 - (empty)
#41 - (empty)
#42 - 30A - Pink - Rear defrost
#43 - 25A - Neutral - Rear heated seats/Steering wheel
#44 - 10A - Red - Park Assist/blind spot/camera
#45 - 15A - Blue - Cluster/Rearview Mirror/Compass
#46 - 10A - Red - Adaptive Cruise Control
#47 - 10A - Red - Adaptive front lighting
#48 - 20A - Yellow - Active suspension
#49 - (empty)
#50 - (empty)
#51 - 20A - Yellow - Front heated seats
#52 - 10A - Red - Heated cupholders/rear heated seat switches
#53 - 10A - Red - HVAC module/in-car temperature sensor
#54 - (empty)
#55 - (empty)
#56 - (empty)
#57 - (empty)
#58 - 10A - Red - Airbag module
#59 - (empty)
#60 - (empty)
#61 - (empty)
#62 - (empty)
#63 - (empty)
#64 - 25A - Neutral - Rear windows
#65 - 10A - Red - Airbag module
#66 - (empty)
#67 - 15A - Blue - Run Sense
#68 - 15A - Blue - Illumination/rear sunshade
#69 - (empty)
#70 - (empty)
quiksilvia
Dec 30, 2007 01:50 PM
Jaso0on
Audio HQ
8
Aug 18, 2004 08:51 PM
Hybrid93Hatch
Apr 23, 2003 09:22 PM
