This worked best for me.
Old Oct 3, 2002 | 08:25 AM
Levi's Avatar
Default This worked best for me.
I had a problem with getting the flywheels bolts out, I wasn't able to keep the flywheel still, while I tried to break loose the bolts.
I did however come up with the simplest way to hold the flywheel.
I used the front motor mount bracket, laid it on the floor, slid it under and into the teeth on the flywheel and turned the bolts, so the teeth were wedged against the mount and it worked great and took me 5 minutes to get all 8 bolts out.
custom parts is our perfection.
Old Oct 3, 2002 | 09:25 AM
whore's Avatar
I like using my Ingersol impact gun
Old Oct 3, 2002 | 10:41 AM
mpbiv's Avatar
Rod Bearing Eater
Damn you people with your air tools.
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Oct 3, 2002 | 10:45 AM
mpbiv's Avatar
Rod Bearing Eater
I have a flexpalte and torque converter, so I just remove the oil pan and when I go to take the converter bolts out with a socket it butts up against the block and keeps the flewplate from spinning. Once I have the torque converter off I stick a long bolt or extension through one of the torque converter bolt holes in the flexplate. Then the flexplate won't move when I go to take it off the crank. But thats an auto
Patrick
Old Oct 3, 2002 | 06:02 PM
CrazyMoparGirl's Avatar
Guest
Flewplate?
Flexpalte?
Old Oct 3, 2002 | 08:30 PM
mpbiv's Avatar
Rod Bearing Eater
Originally posted by "CrazyMoparGirl"
Flewplate?
Flexpalte?
Jig is up
I am an alien. I cannot figure out this english crap.
Blah blah blah take me to your leader
Patrick
Old Oct 3, 2002 | 08:51 PM
Guest
I hope you don't mean Joe.
Old Oct 3, 2002 | 09:34 PM
mpbiv's Avatar
Rod Bearing Eater
How about George Bush
Patrick
Old Oct 3, 2002 | 09:42 PM
leadfootedfool's Avatar
Eat soot
oh boy
clinton had monica
george bush has maurice
just tell me that you kept the blue dress maurice, thats your only hard evidence
Old Oct 3, 2002 | 09:58 PM
mpbiv's Avatar
Rod Bearing Eater
Originally posted by "leadfootedfool"
oh boy
clinton had monica
knew I forgot something
Patrick
