dodge ram help fast!!!
Old Dec 5, 2008 | 06:00 PM
integrada9's Avatar
Default dodge ram help fast!!!
i just got a 2002 dodge ram 1500 and the only problem with the whole car is the passanger side door wont open from the outside but i opens from the inside if anyone knows what the problem is (looks like the latch the connects door to the door jam) or where i can get it fix lmk i know the dealership will do it but for bookoo bucks any help is great and thanks
also it looks like someone tried to pry off the door handle and use a flat head in the key whole to break in but really doesn't look that bad from the outside
Old Dec 12, 2008 | 05:37 PM
A$$hole Garage's Avatar
Take the door panel off and see if the rod that goes from the outside door handle to the door latch is off . just a little help .
Old Dec 15, 2008 | 07:40 PM
integrada9's Avatar
it is so where should i go?? thanks ^^^^^^^^^
Old Jan 2, 2009 | 08:56 PM
chuly2004's Avatar
.lfds
Old Jan 7, 2009 | 09:54 AM
DemonCivic's Avatar
fixed yet?
i'm in land o lakes if you need help
Old Jan 13, 2009 | 04:45 AM
integrada9's Avatar
no its not fixed yet but looking to fix asap
Old Jan 13, 2009 | 04:50 AM
integrada9's Avatar
pm me if you can fix it and location and #
Old Jan 13, 2009 | 10:05 AM
Hay man sorry to leave you hanging thought it was fixed. the rod is off at which end if it is off at the handle it goes there there is a plastic clip that i call a jesus clip you will see them on the rest of the rods , if it is on the other end look at the latch and you will see anarm with no rod (same clip is on that end also) it is not that hard to do . good luck.
Old Jan 16, 2009 | 05:36 AM
integrada9's Avatar
thanks bro
