srt4
Old Jul 6, 2008 | 07:21 PM
uncfan4life1989's Avatar
Default srt4
hey whats up im drivin a 95 neon and was wanting to know how much it would cost to get a good used srt-4 engine....or should i just get the turbo off of one...which would be the better route and how much
thanks
cody
Old Jul 6, 2008 | 08:15 PM
neondriver's Avatar
around 1,000-2,500. the turbo is 200-300. you can use just the turbo but itas kinda a waste because you really cant run high boost without blowing something on a stock motor. if you want cheap and good amount of power get a 2.4 block(i have one for $100) and go to dodge and buy srt pistons/rods (300) right there $400 for basically a srt bottom end throw a stock dohc head on and the srt turbo and your looking at a almost new 2.4 srt motor for 600 and can run the stock wire harness on the older 2.4 so you dont have to deal with the srt wiring crap.
Old Jul 7, 2008 | 07:14 PM
Drivermod03's Avatar
+1 on what he said..2.4 srt internals and ride out.I had a 2.0 turboed and it broke the ringlands on only 11pnds 2.0's are gay..I,m going to spray the crap out of mine till it breaks and swap a 2.4 in after it explodes.
Old Jul 7, 2008 | 07:26 PM
the thing is i dont live anywhere near tampa...i joined this site to get some info on it bc i couldnt find anywhere else that could help me...you guys seem pretty knowledgeable about it...i live in huntington west virginia
Old Jul 7, 2008 | 07:37 PM
neondriver's Avatar
if you need a 2.4 i have a complete bottom end minus pistons/rods ill sell cheap. i was going to do the 2.4 srt but got a runing 2.4 with je pistons already assembled and running. by far best band for the buck and simply throw a dohc head on and the srt turbo will bolt right up you can run 15lbs all day no problems
Old Jul 7, 2008 | 07:39 PM
so im lookin at about 800 for the set-up...2.4 srt bottom end with a dohc head and the stock turbo kit
if anyone has aim im me and we will talk more
uncfan4life1989
Old Jul 7, 2008 | 07:49 PM
neondriver's Avatar
uncfan4life1989
yeah about that, search srt forums.com i came across a set of used srt pistons/rods for 100.00
Old Jul 7, 2008 | 08:34 PM
www.neons.org :: Index
Uncfan:This site has some usefull info...Neondriver: I got some friends with 2.4's let me see what there asking and I'll get with you about yours.
Old Jul 7, 2008 | 08:45 PM
neondriver's Avatar
+1 neons.org has the most info than any other site on neons. if interested i have the 2.4 block, bed plate, 2 oil pumps, 1 waterpump, 2 cranks one good one had spun rod bearing, a good stock clutch/flywheel, oil pickup tube, oil pan, removed balance shaft and chain but needs hole plugged, 2.4 valve cover, even have a 95 harness setup for the 2.4 motor with resistor box for dsm injectors, all for $75
Old Jul 11, 2008 | 09:05 AM
Ahhhh Nick!'s Avatar
Out Of Towner
Yea, Neons.org has all the info you could ever need about this. Plenty of write-ups, pictures & info. You can contact me on AIM if you'd like: Nickisa0
I just finished a 2.4 turbo swap in my R/T so I can tell you everything that you need to do.
What you're basically gonna do is buy a Stratus 2.4 motor and turn it into a low-budget SRT-4 motor. You'll be using every SRT-4 engine part besides the head and the crank. Then just change the firing order for your injectors and spark plugs and install a motor mount adapter and you're done.
