need help
Old Aug 25, 2007 | 02:29 PM
lazarosrt4's Avatar
Default need help
i need to find out how to put a new blow off valve
Old Aug 25, 2007 | 09:30 PM
The Mayor's Avatar
Only does digs!!
what kind do you have?
Old Aug 26, 2007 | 03:12 AM
lazarosrt4's Avatar
greddy
Old Aug 26, 2007 | 06:29 AM
KrazyRider83's Avatar
Fawkin Skittles
You have the hard pipes I'm assuming?
04 Neon SRT - (rebuild time)
03 B5.5 Passat Wagon 1.8T
Originally Posted by efficientkiller
none of this really matters at the end of the day...if you really want to know, the true answer is found in research, why post a ignorant thread & call it a debate? this is exactly why TR gets the critizism it does...
Old Aug 26, 2007 | 08:56 AM
lazarosrt4's Avatar
no i thought i can just put the blow off vavle were the stock one is at ?
Old Aug 26, 2007 | 10:55 AM
Figs's Avatar
No you cannot. You need to buy an aftermarket cold side pipe flanged for the Greddy Bov. You will also need to get a block off plate (which is needed when you go to an aftermarket bov). You remove the stock bov and put the plate in its place.
