idling?
Old Nov 26, 2006 | 05:49 PM
.Seth.'s Avatar
TR Balla Donor Supreme
Default idling?
Ok well sometimes my car will idle really weird when i go to shift(push in the clutch) and as in really weird i mean high, it veries from 2.5k-4.5k, i was thinking it was a vacuum leak or maybe the TPS b/c i need a new TPS sensor, what do u guys think?
it also will act up sometimes when im at a stop and idle at around 2.3k
what u guys think?
Old Nov 26, 2006 | 06:53 PM
neondriver's Avatar
verry possible vac leak, i remember when josiah put my intake mani on and we started it up it reved high..turned out we forgot to put one of the vac lines on. it only happens when you push in the clutch?
Old Nov 26, 2006 | 07:06 PM
.Seth.'s Avatar
yeah it will only happen when i push in the clutch like say i shift at 3.5k if will stick there until i let out then it will go to how ever many RMP's and ive looked for the vac. lines from wat i can see jus looking at it and i cant really find any, someone have a jack wherer we can get under the car and look?
Old Nov 27, 2006 | 03:39 AM
HPNOTIQracing's Avatar
you own a neon and not a jack...??
Uploaded with ImageShack.us
Old Nov 27, 2006 | 01:52 PM
Da_lurker's Avatar
do neons have clutch switches for the pcm aside from the starter interlock??
Old Nov 27, 2006 | 02:00 PM
.Seth.'s Avatar
no i have a jack it jus doesnt fit under the car lol
Old Nov 27, 2006 | 06:09 PM
Josiah's Avatar
Peon on steroids!
you can actually jack it up(even lowered) from under the front motor mount bracket with a standard floor jack....as for what it could be, I would look first at the TPS, then at the ISC(after checking all vacuum lines...the charcoal canister on the passenger's side has some running to it as well) it doesnt lose power in boost does it?
Old Nov 27, 2006 | 06:16 PM
.Seth.'s Avatar
no it doesnt lose any power at boost
u know why after i took out my gauge cluster and took out the white faces gauges the speedo is liek 10mph high and the tach doesnt work at all, u know any reasons y this might happen?
Old Nov 28, 2006 | 04:09 AM
yes the face of the overlay is to thick and it hangs up the needle. if you take it off they should work again.
as far as vacuum i dont have the canister or about any vacuum lines. will that hurt when i boost?
Old Nov 28, 2006 | 01:49 PM
.Seth.'s Avatar
well yeah if u want to know how much boost ur running and stuff and your fpr n cartech begi rrfpr
