difference?
Old Nov 25, 2006 | 12:34 PM
.Seth.'s Avatar
TR Balla Donor Supreme
Default difference?
OK well wats the difference between stock 2.0 cams and R/T cams?
Old Nov 25, 2006 | 01:40 PM
Josiah's Avatar
Peon on steroids!
if you are talking DOHC cams, there arent any, if you are talking SOHC cams, there is about 5hp worth
Old Nov 25, 2006 | 01:57 PM
.Seth.'s Avatar
alrite im talking DOHC so thanks
Old Nov 25, 2006 | 02:40 PM
Josiah's Avatar
Peon on steroids!
unless you are talking 420A cams(eclipse/avenger cams) they are 5hp weaker
Old Nov 25, 2006 | 02:44 PM
.Seth.'s Avatar
well wat motor is in the neon? i always thought it was the 420a
Old Nov 26, 2006 | 05:14 AM
Josiah's Avatar
Peon on steroids!
no, the neon is the D4RE or S4RE, depending on DOHC or SOHC
Old Nov 26, 2006 | 07:06 AM
neondriver's Avatar
read up on this: Neon technical, review, and information site it will give you alot of informations on different aspects of the neon. neons arent 420A i believe thats an eclipse code where the head is switched around(intake in rear). 420 is a comon misconception seeing 420=4 cylinder 2.0 L, sometimes it is alot easier to just say 420A because more people know it than the D4re that it is called
Old Nov 26, 2006 | 08:15 AM
.Seth.'s Avatar
^thanks! theres alot of info on that site and ive only read a little bit of it
Old Nov 26, 2006 | 09:10 AM
Josiah's Avatar
Peon on steroids!
allpar is the bomb, its THE chrysler site...tons of info on T1,T2,T3 cars...strange special editions, plus the old musclecars too
