What will make more power?
Old Mar 16, 2006 | 08:02 PM
SpringHillSRT-4's Avatar
Default What will make more power?
I have stage 2 with toys. right now im running the stage 1 injectors and at redline im at high 11's a/f. My questions is what will produce more power that or run the stage 2 injectors with a map clamp? keep in mind i already have the s2 injectors and map clamp. just wondering if anyone had experimented with that. please let me know thanks shaun
Old Mar 16, 2006 | 09:49 PM
SCXTREME's Avatar
Boost Addict
Stage 2, map clamp it at like a 4.0-4.3 and up the boost.
Old Mar 17, 2006 | 03:55 AM
ACR2NV's Avatar
a.k.a. NeonDan
i would run the S2 injectors with S2 and experiment with the clamp
"if you got turbo lag, you ain't drivin' it right!!!" -Carroll Shelby
Skittles.....tasty arent they?
Try the newest flavors yet?...Orange blast and white mint
I specialize in SRT4 tuning/troubleshooting/repairs.....
Old Mar 17, 2006 | 06:39 AM
cool i think im going to do that. dan i pm'd u the other day with a question about s2 that i was wondering if you ever ran into. my water sprayer keeps on blowing its fuse everytime i try to turn it on. j/w if you maybe had this problem or any suggestion on what could be wrong.
Old Mar 17, 2006 | 07:34 PM
SCXTREME's Avatar
Boost Addict
Put a multimeter on the power lines going to the pump. Check for amps.-voltage-resistance. Depending on what it reads you can determine whether is just drawing to much power and all you have to do is bump up to a higher amp fuse.
Old Mar 18, 2006 | 07:56 PM
tried bumping up the fuse and it blew my instrument cluster fuse. Me and my buddies are baffled. Tried working on it again today and nothing. if anyone is willing to lend a helping hand let me know b/c at this point we are stuck and i want to hit my car. i think everyone has been at this point one time or another. also need help fine tuning the s2 wga. cant get it to go past 16 and it flutters from 15-16 consitently, but itll hold around 14. anyone some help would greatly be appricated. thanks shaun
Old Mar 19, 2006 | 12:25 PM
ReddevilSRT's Avatar
Mine intercooler sprayer was doing the same thing. I took the water pump apart and cleaned it. It was jammed and that is what kept blowing my fuse for the toys. (The housing of the pump will seperate in half.) Once I did this, I installed it back into the washer fluid tank and it worked fine. Hopefully that will work for you!
Old Mar 19, 2006 | 04:56 PM
hey thanks man ill give that a try
