Stock Boost Levels for SRT-4 04
Old Mar 16, 2006 | 12:15 PM
Srt4Viper's Avatar
Default Stock Boost Levels for SRT-4 04
Seems like my boost is a little off lately..
Who knows what the stock boost levels are through the gears.
Old Mar 16, 2006 | 01:09 PM
Nolimitslja's Avatar
I asked this same question a couple weeks ago got no answer from anyone out of like 30 some views. Your best bet is to go to www.srtforums.com and search there you will find it.
Old Mar 16, 2006 | 01:45 PM
Off-Topic's Avatar
hates race traders
like 12-15
Originally Posted by MrNiceGuy
everything offends black people.
Old Mar 17, 2006 | 03:58 AM
ACR2NV's Avatar
a.k.a. NeonDan
depends on conditions, variables, car, and ultimately the pcm
some car will run 10-12psi, stock some run 12-14psi and some will see 14-16psi sometimes. The pcm in these cars can vary the performance based on what it feels it needs to do to achive targeted torque output. I'll save the lecture and say it varies from car to car
"if you got turbo lag, you ain't drivin' it right!!!" -Carroll Shelby
Skittles.....tasty arent they?
Try the newest flavors yet?...Orange blast and white mint
I specialize in SRT4 tuning/troubleshooting/repairs.....
Old Mar 17, 2006 | 04:59 AM
Dano Moparo's Avatar
Grandpa
During normal operation the SRT - 4 turbocharger will emit a very high frequency whistle at full boost 68.9 - 103.4 kPa (10 - 15 psi) during WOT acceleration.
During throttle tip-out, the surge valve will emit a light air “woosh” noise. If there is excessive NVH or other air leak/turbocharger noises, the intercooler plumbing or turbocharger control system may be compromised.
TO identify the source of the concern, check for Diagnostic Trouble Codes (DTC'S) stored in PCM memory. If any DTC'S are present, refer to the appropriate Powertrain Diagnostic Information.
If there are no DTC'S stored, use the folling chart.
CONDITION POSSIBLE CAUSES CORRECTION UNDERBOOST - 20.6 - 27.5 kPa and turbocharger lag at WOT with some air leak noise OVERBOOST - 103.4 kPa (10 psi) or more even at part throttle (could be as high as 137.8 kPa (20 psi) or more). A "Fluttering" noise can be heard during overboost. CAUTION: Engine damage can result from prolonged Overboost. </B>Waste Gate control hose plumbing compromised/disconnected
UNDERBOOST - 27.5 - 62 kPa (4 - 9 psi) @ WOT with "horse laugh" on throttle tip-out. Surge valve control hose plumbing compromised. Repair plumbing
NORMAL BOOST - but turbocharger lag and "horse laugh" noise on throttle tip-out. Surge valve scroll and vacuum feeds reversed Reverse vacuum lines ()
UNDERBOOST - 0-20.6 kPa (0-3 psi) a WOT with loud air leak noise outside vehicle. Turbocharger may emit a "howling" noise. Intercoooler plumbing hose disconnected Inspect plumbing
Very rough idle TIP/MAP sensor hoses connected improperly or TIP disconnected
CONDITION</B>
POSSIBLE CAUSES</B> Low boost pressure, lack of power Clogged air filter Leaks between engine and turbocharger Exhaust restriction Restriction in charge air cooler hose(s) Wastegate stuck open Wastegate actuator malfunction Seized turbocharger shaft Overboost Wastegate stuck shut Wastegate actuator malfunction Noisy operation or vibration Leak(s) in charge air cooler hose(s) Intake or exhaust leaks Oil starvation Worn turbocharger bearings Damaged turbine/compressor fins Blue smoke from exhaust Oil return line blocked Engine breather clogged Turbocharger shaft seals damaged
Old Mar 21, 2006 | 03:18 PM
91 TURBO's Avatar
im a ricer!!
i have the same prob, but its my gauge. when you shut off the car, what does the boost gauge read?
Old Mar 27, 2006 | 10:44 AM
Srt4Viper's Avatar
it reads -2
Old Mar 27, 2006 | 04:39 PM
91 TURBO's Avatar
im a ricer!!
it should go to 0. so, your gauge is off a few pounds.
Old Oct 7, 2009 | 07:38 PM
Boosted SRT4's Avatar
Default I have a 05 srt4 and i need it tuned can anybody help me with that
i have a aftermarket hks bov an intake frontmont thats all i know for sure i just bought it so i dont really know but i tink everything it stage 2 so can anybody help
Old Oct 8, 2009 | 12:42 PM
fallen4ng31's Avatar
Cogito ergo sum
What the hell are you blathering about, man?! If you have a technical issue, make your own thread; Don't jack someone else's, and certainly don't bump a thread that's 3.5 years old.
That said, what is your issue? I couldn't make sense of that...that... sentence.
"Kid, If you call me 'bro' one more time, I swear to Christ you're going to find out what your left testicle tastes like."
I offer professional computer / network services and consulting.
Over 10 years of industry experience.
A+/Network+/Security+ Certified ; CISCO CCNA, Novell CNA, Microsoft Certified IT Professional.
