T-stat?
Old Feb 16, 2006 | 07:43 PM
Nolimitslja's Avatar
Default T-stat?
Can you put in the 180 t-stat without having to drain the radator? Also whats the stanton part number for the t-stat?
Old Feb 16, 2006 | 08:11 PM
HMCK20's Avatar
FML
yes you can and the STANT not stanton number for the 180 is 29788
'11 2.0T R-Spec Bathurst Black
AA M4, Glock 17 36, P22 Mil
Old Feb 17, 2006 | 03:31 AM
ACR2NV's Avatar
a.k.a. NeonDan
correct brotha...
Stant 29788
"if you got turbo lag, you ain't drivin' it right!!!" -Carroll Shelby
Skittles.....tasty arent they?
Try the newest flavors yet?...Orange blast and white mint
I specialize in SRT4 tuning/troubleshooting/repairs.....
Old Feb 17, 2006 | 06:01 AM
SpringHillSRT-4's Avatar
is putting the 180 in there really helpful. i have heard many people argue both ways that it helps and other say it hurts b/c you car was made to run optium at 200.
Old Feb 17, 2006 | 06:10 AM
Thanks guys rep points for both you guys if you even care and sorry about that mispelling I couldn't remember it exactly I knew it was something like that (I just got home from a long day at work. Also I took a picture of where I think the t-stat goes if I'm correct someone just verify it for me I'm trying to make this as simple as I can for my self, I've only done one t-stat before and it was by a hayes manual so anyway thanks for the help again guys.
Old Feb 17, 2006 | 07:24 AM
bluelighting's Avatar
You are correct. It's quite easy to do. just put a bucket under your car where the T-stat is, becasue you are going to leak a shitload of coolant. All you have to do is take out the 2 black bolts, and remove the t-stat, then use the stock gasket, and put it back in, then refill coolant. I think it took me like 15 minutes max.
2005 GTO
Old Feb 17, 2006 | 10:56 AM
Mike K.'s Avatar
aka Distortion
Hes correct..Always good to add a little Distilled water and you should be good..Dont be suprised if it leaks a lil for a couple days after cause I added mine and then the over-flow spurted a little out cause I added too much water..
Mike
My Flickr Page:http://www.flickr.com/photos/mkloepfer/
Old Feb 17, 2006 | 11:51 AM
HMCK20's Avatar
FML
actually if you use a hose clamp tool on hose from the rad to thermo housing you wont loose more than a few ounces of coolant. make sure you purge the system after you install the stat.
now on the temp gimmick, some reasons your motor needs to run at a ceratin temp is for the material that the block and such is made of. its kinda hard to explain but at ceratin temps metal becomes more "slick", oil temp, and lots of other reasons. but in reality you may have a 180 stat but the car still runs around 190 so watch out 10 degrees is gonna kill your motor. but you also dont want to go to cold. another thing you might want to do is the fan switch mod. hope i explained it good im sick as hell so it might not make sense
Old Feb 17, 2006 | 12:33 PM
I hope you meant to say 10 degrees ISN'T gonna kill your motor cause I did it already and I only lost a couple ounces cause I wore some gloves I have for yard work and just pulled the hose off and tilted it up as quick as possible and didn't lose much at all just what was in the housing. It was easy and took me a total of about 15 minutes tops thanks for everyones help it's much appreaciated.
Old Feb 17, 2006 | 01:01 PM
HMCK20's Avatar
FML
lol yes, inst was what i ment to type
