Chassis & Suspension Tech Cages, braces, suspension set up and more
AFCO Introduces Terminator Spindle Mount Adjustable Struts
Old May 21, 2018 | 08:03 PM
Default AFCO Introduces Terminator Spindle Mount Adjustable Struts
By Chris McWilliams May 11, 2018New from AFCO – the Terminator Spindle Mount Adjustable Struts. These struts are the most advanced and most adjustable spindle mount strut available today. See more details below. Official Release:AFCO is proud to bring to market the most advanced and most adjustable spindle mount strut available today. Sporting a large 46mm monotube piston, the range of adjustment is un-matched to enhance tuning and performance. You will not find a more user friendly adjustable strut at any cost. Each adjustment is metered with a detent for precise adjustments. These struts are available in 3 lengths to fit virtually every ride height. A perfect choice for “No Prep” style of racing, the “extra travel” models promote additional weight transfer to hook on low traction surfaces. For more conventional applications, the new AFCO Terminator Series Struts are offered in common lengths to retro fit to existing chassis in the field or new builds that need to fit an existing jig.Double adjustable struts allow for nearly infinite chassis tuning combinations, but more importantly, the broad range of adjustment offered will allow tuners to find the sweet spot quickly and efficiently. Features:
  • 3 lengths are available to fit most tube chassis applications.
  • 100% Dyno tested for accuracy and quality.
  • Double Adjustable 46mm monotube design provides broad range of adjustment.
  • Fully independent compression and rebound adjustments for ultimate tuning and performance.
  • AFCO Exclusive aluminum steering arm gives better tire clearance. “Competitor style” steel steering arm allows you to upgrade to an AFCO strut without having to shorten tie rod assembly.
  • Pro style coil-over spring adjuster nut has positive clicks with each turn, locks in place with an allen wrench and has pronounced finger grips to aid setting ride height. Spanner wrench may also be used to set ride height.
  • 2 or 4 piston caliper brackets available.
  • ’67-’69 Camaro pin design for common wheel/brake kit fitment.
  • Best front end control on the market!
Article Sources
Old Jul 23, 2018 | 03:08 PM
The New AFCO Door Car Strut
Seeing the advantages a good front strut can bring to any racing program is something that any racer focused on winning would want to take advantage of. To address this, AFCO has designed a new spindle-mount strut that works on 1979-’93 Fox-body Mustangs, 1994-’04 SN95 Mustangs, 2005-’14 Mustangs, 1982-’92 Camaros, 2010-15 Camaros, and other applications. This longer strut has a universal construction that allows it to be used on either the left or right side of the car, and it’s packed full of features that racers will love.
We have worked very hard on providing the tuner with the ability to soften the extension and rotate quickly, or tighten down the extension and see very little drop out of the strut at launch. – Eric Saffell
Since this strut is a longer unit, it will be able to give racers some additional adjustability that normally wouldn’t exist due to the layout of their car’s chassis.
“This model is available in four-inches of travel for cars that are sitting at a low minimum ride height and six-inches of travel for cars that, due to their ride height, require a longer unit. These struts are popular for Mustang applications, but also for non-Ford applications like the Chevy II where the O.E.-style front end isn’t good for drag racing or any chassis requiring a longer spindle-mount strut,” Saffell explains.
When a racer opens the box from AFCO, they’re greeted with a complete kit that will help make installing the struts fairly easy, which includes all the necessary hardware and appropriate steering arm as ordered.
The aluminum arm offered has been designed for a new car build and will locate the heim joint away from the wheel and tire to provide extra clearance. AFCO also has the option of a steel steering arm that is designed for race cars that are already completed where adjusting the tie rod ends isn’t available without some fabrication. This option is more like a bolt-on or conversion process to use the new strut.
Old Jul 23, 2018 | 03:09 PM
The door car strut is available for several different applications and will help optimize suspension travel for any form of racing.
What these struts will provide to a racer is the ability to make solid adjustments with just a few clicks of the dial. Now, the racer can allow the front end of their car to move quicker when it launches to get more traction, control wheel speed, and become more consistent. The racer will also be able to make the extension of the strut stiffer to slow the rotation of the chassis when they have more traction available.
These are all critical items that a racer can use to help dial in their car in for specific track and weather conditions that will assist in making their car infinitely more predictable. Having that kind of control at their fingertips will make putting together a solid run much easier, therefore increasing their chances of winning in changing conditions during the racing season.
AFCO has beefed up its steering arm considerably, including where the tie rod attaches to the new struts, for extra rigidity.
The New AFCO Chassis Car Strut
With the rising popularity of Top Sportsman, Pro Mod, and oher forms of fast door car racing, AFCO decided to design a new strut that was dedicated to the chassis car market. This strut has a shorter stroke in a mono-tube design that also uses a double-adjustable canister. The strut is unique because of its size, tube design, and use of a canister all mixed into the same part. Thinking outside of the normal confines of strut design allowed AFCO to create a unit that can cover multiple applications with ease.
In this screenshot from the Racepak that was taken on the first run with the new struts, the green (shock movement) and red trace (engine RPM) lines represent the front struts moving when the car launches. This shows the struts are able to quickly extend when O’Neal releases the transbrake at the start of the run. Since this run was made during the heat of the day and on a marginal track, the goal was to get the weight to transfer as quickly as possible for a baseline to make more adjustments.
The strut will come in three different lengths that can work in a variety of situations for different racers. A 2.5-inch travel strut is the first one that racers can choose that will replace struts of the same length, and it will provide a variety of adjustment points. The next strut will have 3.5-inches of travel, and this length can provide the tuner additional travel upward to give more performance and traction.
Old Jul 23, 2018 | 03:10 PM
In this graph, the strut traces are highlighted in blue and yellow trace. The rise of the angle and height of the traces are lower than the first graph from the first run. The track was in much better shape for this pass, so O’Neal was able to tighten the front end for better control pitch rotation. Since the chassis car strut offers a wide range of adjustment, O’Neal has the ability to tune the car for different track conditions like the marginal track on the first run, to the favorable track on the second.
Finally, the strut will be available in a 4.5-inch travel size. At this length, the strut can be used on cars that require a taller strut for more travel that provide a higher level of traction on a lower traction surface. With the increase in popularity of no-prep drag racing, this length should prove popular for builders and tuners wanting maximum adjustment.
The range of adjustment from soft to stiff is the widest on the market. – Eric Saffell
With a new strut like this, AFCO can offer a racer, tuner, or chassis builder a new arsenal of tuning options for a racecar.
“The range of adjustment from soft to stiff is the widest on the market. Each adjustment is denoted with a click, offering the ability to count the number of clicks promotes exacting adjustments and removes guesswork when trying to count partial rotations. Also, with the ability to custom-valve these units, we can offer much more versatility and control than other brands on the market. As an example, we can install our Big Gun valving on extension to lock down the front on high horsepower applications,” Saffell explains.One of the key features that AFCO incorporated into their chassis car strut is a nitrogen-filled canister. The canister itself uses a large piston inside that provides damping options and characteristics for cars that are making a lot of horsepower.
The canister system on the chassis car strut is compact in size, but robust in its abilities. These canisters can be mounted anywhere around the strut to make adjusting it a breeze.
Saffell explains further how these canisters help the chassis car strut function so well.
“The remote canister strut promotes a very wide range of adjustment on the extension and compression side for maximum tuning and control. The nitrogen charge in the canister eliminates cavitation or loss of damping control during the run. The internal pressure maintains a stable column of oil which further enhances full adjustment and chassis control.”
Inside the strut itself, AFCO paid close attention to the valving package, which makes the strut a potent product right out of the box. The valving that comes in the strut will cover the majority of applications for racers who purchase the struts.
“This standard package will have a very wide range of adjustment to promote tunability and control. However, custom valving is always an option,” Saffell says.
“We tested at Ohio Valley Dragway with the car and were pleased with the results. Our first run we allowed the strut to fully drop out. Because the track was so good and the car hit the wheelie bars so hard, we stiffened the extension on the front struts through two more passes to the extent that the front wheels were only dropping out 3/8-inch before the front end touched back down. This showcases much control these struts provide,” Saffell explains.
Making big power is easy, but being able to get that power to work for you is the key to winning at any level of drag racing. AFCO’s new struts provide racers with a plethora of options to help make tuning their cars much easier. In a world where “spinning ain’t winning,” AFCO’s struts will keep your car glued to the track no matter what the conditions are.
Drag Racing
5
Mar 22, 2019 02:39 AM
Mar 7, 2019 11:40 PM
Mar 7, 2019 11:39 PM
Jul 23, 2018 03:15 PM
Jul 23, 2018 03:07 PM
