Coilover preload for dragracing? (FWD)
Trying to get the best 60ft time I can on street tires.
How should I have the preload set on the front/rear? Launch style is 4500~ rshared_pm and feather the clutch. Tires are kumho 195/55s. |
fwd you are gonna want the rear as stiff as poss on preload, rebound on the shock loosey.
Originally Posted by treekiller
(Post 8441229)
That's what I figured on the rear's, how about the front? Thanks for the help. |
just buy some tires lol its the only thing that is gonna bring yer 60ft down noticably.
I plan on it, but I'd rather have my suspension setup properly before I go and throw some DRs on.
are you preload launching with the E-brake? Also wouldnt the rear rebound being stiff be better because the weight would want to be thrown back but it will push it forwar fast and regain traction? IDK
Stiff rebound RESISTS allowing the suspension to extend. As you said, you want the rear weight to come forward more quickly when you lift or shift to regain full traction. Minimal rebound on the rear shocks will do that. You want stiff compression damping on the rear to keep the weight transfer OFF of the front tires very well controlled.
Edit: You're confusing stiff springs with stiff rebound damping. Two different things. |
Originally Posted by Loren
(Post 8452205)
Jeff might answer that question better. I'm not up on all the ins and outs of preload. I'm inclined to think that it wouldn't make that much difference as long as you have enough preload to keep there from being slack in the spring at full suspension droop.
You are supposed to set rebound 1st and then compression.
