Chassis & Suspension Tech Cages, braces, suspension set up and more
my Ground control coilovers
Old Mar 22, 2010 | 04:39 PM
robertmathewson's Avatar
Default my Ground control coilovers
quick question for you . it was a little chilly out tonight, and i was at the light on the brake , and it sounded like the springs were squicking when i pressed the brake , and the wieght shifted to the front . just not sure if thats normal when its cold out , or maybe when the cars not warmed up yet .... Any one else have this prob ???
< joga bonito > < play beautiful >
Old Mar 23, 2010 | 01:07 PM
Ether811's Avatar
Lead Farmer
did you replace your struts when you put in the GCs?
Old Mar 23, 2010 | 05:15 PM
jdmgt35r's Avatar
your shocks are blown?>
Old Mar 28, 2010 | 04:07 PM
I would check to be sure the springs are seated properly.
Some other people on TR have lowered cars too far
to the point that the springs flop around and make noises,
sometimes rubbing against the side of the shock....
I would check to be sure all the rubber seats are in place.
Some people leave them out and the springs rub against the
seats as they are compressing/decompressing....
Understand that as a coil compresses, it rotates slightly, and
leaving out the rubber sometimes makes noise....some MFG's
will have one or more bearings at the top of the spring that allows the
shock to rotate quietly....if the bearing is not sealed, it needs
clean lubrication....
When people have brought their cars to me, those are things I have found. Picky as I am, when I install for other people,
I even seat the spring in the exact spot it was previously installed
in, as it makes a better seat.-Bob
Old Apr 1, 2010 | 12:22 PM
treekiller's Avatar
legend behind the cowl
Sure if your spring is too short and not captured under full droop this can happen. I have some spare Used helper springs and spacers we can install if you need them. the helper springs are fully compressed in normal situations but keep a small amount of pressure on the spring by your Avatar I assume you drive a honda. but depending on the suspension design (strut or shock) they behave differently. AFAIK GC does not include any noise isolators, you can add them, but if you capture the spring it corrects 90% of the noise.
