Chassis & Suspension Tech Cages, braces, suspension set up and more
Shock recommendations...
Old Dec 22, 2009 | 10:34 PM
SmokinS13SR20's Avatar
That ginger...
Default Shock recommendations...
Vehicle: 85 nissan 720
I just flipped my middle leaf and it dropped me about 3" inches.
Now, I have a few questions.
Will GR-2s or gas-a-justs handle that much lowering, or will they blow out shortly?
What shocks would you recommend using?
Would I be better off going through kyb's catalog and finding a shock that is 3" shorter comrpessed/expanded with the same mounting styles?
Thanks...
Old Mar 19, 2010 | 08:09 AM
Looks like people may have ignored you.......
Look also for approx the same weight vehicle.-Bob
Thanks...
Old Mar 22, 2010 | 04:38 PM
robertmathewson's Avatar
i droped my acura 2inchs , i went with the kyb-gr2 ... i love them !! you might want to get a adjustable shock , if your that low ... better safe than sorry .. Good luck
< joga bonito > < play beautiful >
Old Apr 1, 2010 | 12:26 PM
treekiller's Avatar
legend behind the cowl
I Put some Edelbrock Monotube racing dampers on my flip kitted, and Coil sprung Ranger. I have them for sale $40/each if you want them. they only have a few hundred miles on them, and are fitted with Spherical Bearings on both ends, not cheap Rubber.
If you want I can help you engineer a solution, since I have a TON of catalogs on my computer to scan through. feel free to call the shop 813-333-1100
