Chassis & Suspension Tech Cages, braces, suspension set up and more
Shock Dyno and coilover rebuild special
Old Aug 22, 2008 | 07:18 AM
treekiller's Avatar
legend behind the cowl
Default Shock Dyno and coilover rebuild special
Have been added to Tampa Rally Website.
tamparally.com - Shock and Suspension Services
Clean, inspect and Dyno a coil over, Shock, or strut $30/each
Limited time special (Minimum 2 Dampers)
Clean, Inspect, and Rebuild a damper $150/each
(Minimum 2 Dampers)
Broken or worn out components may add cost to the rebuild. please call, for custom re valves, or Double/Single adjustable conversions at the same time.
All Rebuilds are done with U.S.A. sourced seals, and MOTUL, multi viscosity fluid, (much more tolerant of florida heat)
We have in house parts, or experience with the following Manufacturers
KONI, BILSTEIN, JIC-MAGIC, K-SPORT, TEIN, MEGAN, PENSKE, D2, APEX, APEXI, KW SUSPENSIONS, KYB,TANABE, BELLTECH, SKUNK-2, CUSCO, EIBACH, STANCE, FOX, CARRERA, OHLINS, HKS, H&R, BLITZ, BG, AND OTHERS
Old Aug 22, 2008 | 08:37 AM
RoadRacer's Avatar
Turn 7 at Sebring
Good to know.
Is the dyno local, and what is the turn around time?
Patrick -
Old Aug 22, 2008 | 09:32 AM
treekiller's Avatar
Originally Posted by RoadRacer
Good to know.
Yes Dyno is local, I am trying to book a whole day to keep my costs down, but I dissemble, inspect, and catalog, figure no more then 1 week to check everything out, and if I find something wrong when I dissemble I'm not going to have the customer pay to dyno them until we can get them fixed.
Jeff
