About the ASNU Fuel Injector Flow Bench
Old Aug 25, 2010 | 05:52 PM
Kirk's Avatar
Boostaholic
Default About the ASNU Fuel Injector Flow Bench
The ASNU gasoline injector flow bench has brought state-of-the-art technology to petrol fuel injector testing, fuel injector cleaning, and fuel injector servicing.
If you want to "get serious" with your vehicle's performance, then your fuel injectors need to be tested and cleaned, on the ASNU bench tester, such that your injectors are returned to as-new condition. Balanced fuel delivery from your injectors is paramount for your engine to provide maximum HP, the best fuel economy, lowest emissions, and overall driver satisfaction.
We are proud to use the ASNU injector bench tester equipment in our shop.
This equipment has the ability to perform the following testing and cleaning of gasoline injectors...
  • A visual precleaning test of injector spray pattern.
  • A quantitative precleaning measurement of injector fuel discharge volume flow.
  • A precleaning pintle/orifice seal leak test.
  • A precleaning pressure test for manufacturing/or damage defects for mechanical leaks. Mechanical leaks are non-repairable and the injector(s) must be replaced. In most cases...we have replacements on-hand.
  • Ultrasonic cleaning in a chemical bath to chemically and ultrasonically breakdown "baked-on" fuel deposits.
  • A visual post cleaning retest of injector spray pattern.
  • A quantitative post cleaning measurement of injector fuel discharge flow volume.
  • A post cleaning pintle/orifice seal leak test, and mechanical leak test.
  • Injectors can be tested across a wide range of simulated engine rpms and injector pulse timings. Range simulation can be from 3 to 12 milliseconds, and from 600 to 10,000 rpms.
  • Injectors can be tested at normal fuel pressure and also at 1 bar below and 1 bar above normal fuel pressures. Normal test pressure is 3 bars. (1 bar = 14.7 psi)
  • Separate digital test equipment is also used to test ohms resistance for compromized/grounded coil windings.
  • A visual inspection is also performed to look for external and internal rust on and within the injector. Internal rust may/or may not be removed via cleaning. We will do everything possible to eliminate inernal rust...however...there is no guarantee. Injectors with external rust will be wire brushed to remove rust. External spray painting is also available.
Maximum performance of your vehicle's engine requires injectors to be balanced in all aspects of spray pattern, flow volume, no leakage, and electrical integrity.
The ASNU bench tester and the additional electronic testing allows us to flow test, clean, retest, and return a set of injectors in "as-new" condition.
Most injectors can be serviced. However, injectors that fail any test can be replaced with cleaned and rebuilt injectors ( if available), with matching characteristics to provide a balanced set. If rebuilt injectors are unavailable, new injectors with matching characteristics will be available.
A picture is worth a thousand words.....
Before:
After:
www.TheBoostLab.com
813-443-0531
8602 Temple Terrace Hwy
Suite D12
Tampa, FL 33637
BOOST LAB, INC.
95 Toyota Supra Turbo - 1000HP
http://www.TheBoostLab.com
TURBO SERVICING & SALES | FUEL INJECTOR SERVICING
GARRETT - BORGWARNER - BULLSEYE - HOLSET - 3K
TiAL - TURBONETICS - FULLRACE - PRECISION
Shop Forum | FaceBook | Website | Online Store
Old May 3, 2011 | 07:33 AM
FICINJECTORS's Avatar
Great machine, we have 3!
Old May 4, 2011 | 02:43 PM
Kirk's Avatar
Boostaholic
We have 2 at the moment as we operate two locations. A customer of mine has one of the original 1980 ASNU's and it is still running without a single hitch!
BOOST LAB, INC.
