BMW / Mercedes Tech Germany and its finest
auto e36 328i tranny
Old Sep 21, 2009 | 11:41 AM
manchesi's Avatar
Default auto e36 328i tranny
so does anyone know much about the auto trnnys on e36 328i. i wanna chnge the fluid but i know they say its lifetime but mine shifts really hrd and its slipping i think it might be low..
Old Jan 24, 2010 | 08:15 AM
94e36's Avatar
There should be a drain plug and a fill plug I have a 325i and they are on the driverside. I called some dealer and they said it was reagular dex3. Im just waiting on getting the filter and pan gasket and gonna do mine.
Old Jan 27, 2010 | 09:03 AM
AlienBlood's Avatar
Old-school
Manchesi, if it's slipping, don't even think about changing the fluid, or you stand a good chance of making it worse, or killing it completely. If it's still driveable, swing by the shop and I'll run a diag on it to see whether it's the transmission itself or one of the control mechanisms (sensor, TCM, loose wire, etc.), and help figure out a course of action.
And yes, it takes standard Dex III (standard service) or Shell LA2634 (lifetime service).
address & phone number in my sig.
Service Manager,
BMR Enterprises
5113 16th Ave South
Tampa, FL 33619
813-247-2444
Old May 1, 2010 | 08:57 PM
kirbykirb's Avatar
There is no drain plug; to change fluid you need to remove pan, dump fluid, take out magnet clean it up. New filter, new fluid. Drive 500/1000 miles, and change fluid and new filter because you can't drain the fluid from the torque converter when doing a flush.
Sometimes you may need to do three flushes + add some lucas transmission additive before it acts better.
But if its over or near 150,000 miles, don't bother just buy a used tranny and swap in.
