BMW / Mercedes Tech Germany and its finest
1999 3.28i Computer
Old Mar 12, 2009 | 10:08 AM
95GS-r's Avatar
Night Rider
Default 1999 3.28i Computer
I'm lookin' into buying a '99 3.28i (e46 Sedan). The only problem is that the computer that controls the odometer, speedometer, and I think the warning lights isn't functioning. Questions:
1. What is the proper name of this part? Is it just the on-board computer?
2. How much does it typically cost to repair it (if it needs repairing, and wasn't just disconnected)? It's manual trans.
Thnx.
Old Mar 12, 2009 | 12:09 PM
lennon's Avatar
e30 addict
i dont have much experience with e46 just older ones, but i dont think theres a separate computer for those things. the on board computer is just a name for the screen and buttons that scroll through info like mileage and temperature. im too lazy to research e46 right now haha but all that and the instrument cluster should run off signals through the main ECU. it could be the instrument cluster itself is messed up which is pretty common/cheap/easy to fix. it should be a simple fix, even if it isnt the cluster i cant imagine anything crazy or expensive that would cause those things to not work.
take all that with a grain of salt because i have not owned or worked on an e46 ever in my life. driven my friends sick 330 zhp 6 speed all the time though!
any reason you chose an e46 328 out of all models?
Old Mar 13, 2009 | 12:15 PM
tobibeck80's Avatar
Nordschleife addict
Go to the stickys of this forum, I posted a BMW part search website where you can look for every single screw a BMW is made of including the part numbers, no matter the model.
Its the same concept every BMW dealer uses.
Old Mar 13, 2009 | 09:03 PM
lennon's Avatar
e30 addict
wow great info
