BMW / Mercedes Tech Germany and its finest
bmw code reader?
Old Nov 12, 2008 | 07:33 PM
hockeyfreak007's Avatar
The Deliverer
Default bmw code reader?
anyone have a bmw code reader for a 95 325i? i need tofind what codes im throwing, my obc just tells me about my faulty coolant level sensor(previous owner busted hte plug if anyone knows where to get a plug from the harness cheap), but i want to make sure nothing else is wrong with it
thanx
parker
BImmer sold
Integra SOLD
http://hitemptech.com/ - HiTemp Technology Corporation – Specialists in high temperature (hi-temp) technology, non-burning technology, fume incineration and custom processing furnaces.
Old Nov 12, 2008 | 08:04 PM
jriggs's Avatar
is better than you™
autozone will check your codes for free if you tell them you have a cell on
Old Nov 13, 2008 | 03:37 AM
bam2002's Avatar
I thought you could do a push in the gas pedal X amount of times and it will flash you a code on the dash. then look that up on the Net.. thus giving you the diag.
It works that way on the E30s. and E34s.
Google it..
Or if that is what you have already done thus the coolant temp, then try shorting the wires and seeing it the warning goes out. of so its the switch and check a U pull. Or I am sure any local shop can order one.
Old Nov 13, 2008 | 07:14 AM
The Deliverer
the pedal doesnt work as the previous owner cut some wire down there, so i have to try to fix that before i can try it as code reading. and reeves says u have to buy complete engine harness and all parts stores around say dealer only....will have to find a u pull it that actually has a e36 as none seem to have one.
BImmer sold
Integra SOLD
Old Nov 13, 2008 | 09:35 AM
jriggs's Avatar
is better than you™
if the wires are only cut you should be able to patch them back together, it should be color coded down there. unless he hacked everything up and pulled wires out
Old Nov 13, 2008 | 09:58 AM
The Deliverer
yea thats what im going to try to do now actually...wish me luck
BImmer sold
Integra SOLD
Old Nov 13, 2008 | 10:09 AM
jriggs's Avatar
is better than you™
make sure all the connections are rock solid. good luck, let us know the out come so we can attempt to over diagnose the problem
Old Nov 13, 2008 | 10:14 PM
The Deliverer
so found the wire that was cut but it wasn't part of the loom so not sure if previous owner tried to fix it, but i brought it to the original autohaus and they found out its a o2 sensor and a knock sensor they said.
BImmer sold
Integra SOLD
