rear cylinder is miss-firing…everything checks out
Old Jan 19, 2017 | 03:07 AM
Default rear cylinder is miss-firing…everything checks out
james
hi! i just put together a new top end for 1988 sportster with nhrs stage 2 thunderstorm heads and new pistons/cylinder work by nhrs…i’ve completed the “heat cycles” and took her for her first easy mile ride…i’m using a mikuni hsr 42 carb and cycle shack 2 into 2 pipes…running compu-fire 21850 selectable electronic advance ignition…static timed it…my prob is the rear cylinder is miss-firing…everything checks out…no intake manifold leaks or exhaust leaks…rear cylinder feels cooler than the front cylinder…timing?? carb?? i can’t figure it out…thanx!! -james.
Old Jan 19, 2017 | 03:08 AM
Customer Service Techs Hi James
Make sure the pushrods are adjusted correctly.
Check ignition timing
Try swapping the spark plug wires. Front to rear / rear to front. See if anything changes.
Old Jan 19, 2017 | 03:09 AM
james
hi! did a compression test with engine at op temp, front 195+ rear 195+….readjusted pushrods, rechecked timing, good spark, battery good…still misses on rear…plugs?? starter solinoid?? havn’t checked charging system, not sure how to…nothing changed swapping plug wires…i don’t get it… ugh.
james
hi! did a compression test with engine at op temp, front 195+ rear 195+….readjusted pushrods, rechecked timing, good spark, battery good…still misses on rear…plugs?? starter solinoid?? havn’t checked charging system, not sure how to…nothing changed swapping plug wires…i don’t get it… ugh. running andrews v4 cams, mikuni hsr 42, 1988 xl cycle shack M pipes…
Old Jan 19, 2017 | 03:10 AM
Hi James. As far as testing compression goes; it is typically better to test Compression, cold, when you are trying to diagnose a performance issue. Testing compression @ running temperature is fine, but expansion from heat can sometimes disguise a problem.
Make sure that you are adjusting your pushrods, cold. Also, you need to be confident that your Andrews cams were installed/timed correctly.
You may have a failing ignition, or coil.
Check your charging system and check for an intake leak.
Mazda Tech
May 13, 2014 10:23 AM
auxilium
Sep 15, 2008 03:07 PM
Fake STI Guy
Subaru Tech
8
Aug 29, 2003 08:00 PM
