Need a motorcycle technician
Old Feb 28, 2007 | 10:53 AM
hmonglonertim's Avatar
Default Need a motorcycle technician
I want someone who you have dealt with and had a positive experience. I would try to figure it out on my own but wanna get it going before I ride out to Daytona this weekend.
Problem = Bogs when accelerating. Idles fine and revs up fine. Only accelerates fine when doing so ever so slowly.
Old Feb 28, 2007 | 11:00 AM
Cecil's Avatar
gone fishin
Chris Murphy
813-494-8703
Ultimate Performance Cycles
17604 US Hwy 41 N
Lutz FL 33549
He's good people.
Old Feb 28, 2007 | 06:36 PM
CBER's Avatar
are you asking us to help u here online? or bike shops that can helps you? if so theres plenty of shops around to to helps you, but if u're asking for helps here then what bike and year is it? and is it carbed? do a search on forum i think theres couple people have similar problem on here, its could be alot of things but check few main things first like fuel pump, petcock, air hoses under the gas tank and air vents , to check as in checking if its geting air,hoes isn't bent, or fuel pump isn't clogged up, then if all eles failed then take it to the nearest shop.
Old Mar 1, 2007 | 07:28 PM
My bad. Bad post by me. I just read it now. It's an 04 R6 but a buddy of mines and I was able to fix it. Turns out the lean angle cut off wasn't mounted properly. Thanks all. Daytona here I come...
