anyone know the specs on the 06 gsxr 1k?????
Old Oct 7, 2005 | 04:51 PM
JDM-EG6-Hatch's Avatar
Life's short ride hard.
Default anyone know the specs on the 06 gsxr 1k?????
Im looking for the hp and how much ft. lbs. it makes to the wheel stock i searched for probably an hour and found nothing anyone know anything. lmk if you can find anything.
Old Oct 7, 2005 | 06:24 PM
{{HEAVYDUTY}}'s Avatar
If you doubt me,try me!!!
I bought my 06 gsxr about a month ago and from what the guy at the dealership told me its about the same as the 05
need a realestate agent contact me.
Run your car not your mouth!!
2006 GSXR 1000
1988 CRX SI "All Motor"
"not 4 long"
It's my dick and i'll wash it as fast as i want to!
Let me guess? You missed a gear!!!
FUCK BARNEY'S!!!!!!!!!!!!
Old Oct 7, 2005 | 06:33 PM
here is some info hope this helps.............
Engine: 998.6cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC®
Bore Stroke: 73.4 x 59.0mm
Compression Ratio: 12.5:1
Fuel System: Fuel Injection
Lubrication: Wet Sump
Ignition: Digital/transistorized
Transmission: 6-speed, constant mesh
Final Drive: #530 chain
Overall Length: 2030mm (80.0 in.)
Overall Width: 710mm (28.0 in.)
Overall Height: 1130mm (44.5 in.)
Seat Height: 810mm (31.9 in.)
Ground Clearance: 130mm (5.1 in.)
Wheelbase: 1405mm (55.3 in.)
Dry Weight: 166 kg (365 lbs.)
Suspension Front: Inverted telescopic, coil spring, fully adjustable spring preload, compression and rebound damping
Suspension Rear: Link-type, gas/oil-damped, fully adjustable spring preload, compression and rebound damping
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 120/70-ZR-17
Tires Rear: 190/50-ZR-17
Fuel Tank Capacity: 18 liter (4.8 gal.)
Color: Blue/White, Silver/Gray, Red/Black
2006 GSXR 1000
"not 4 long"
Old Oct 7, 2005 | 06:37 PM
Cecil's Avatar
gone fishin
Dyno'd a bone stock '06 at Synergy last week... 156rwhp.... not bad eh
Old Oct 7, 2005 | 07:02 PM
C4_crusin's Avatar
150+ in the emergencylane
mine made 154 stock at kinetic motorsports (1200 miles)
pipe and pcIII put down 161
now i got a bmc and a tre needs to be retuned (finally broke it in)aiming for 162+, it shoots big blue flames though
got glafers rotors(backordered),pads,lines coming.....hopefully have them on by the 16th when its track time... looking to build the motor but dont know where to start (bottom-->top or top-->bottom) anyways enough braggin
D-1SC procharger f/s $2500 with injectors and TPIS fuel rail, <1000miles
AIM:gsxrpat76
Old Oct 8, 2005 | 08:59 AM
isnt that what bobster put down after his mods or was it in the 160's???
2006 GSXR 1000
"not 4 long"
Old Oct 8, 2005 | 10:28 AM
Cecil's Avatar
gone fishin
Bobster's bike made 170rwhp!
Old Oct 8, 2005 | 10:39 AM
Thanx, for teh help i was just looking at the hp; and ft. lbs of torque i already knew everything else thanx for all the help.
