may have been making a mistake
Old Aug 20, 2005 | 05:18 PM
sl2racer's Avatar
Default may have been making a mistake
okay well this time with the next clutch i decide to go back to oem honda friction plates and steels. well i case anyone wanted to know my last clutch ended up looking like black chalky charcole.
well i start the install but i decide to relook at the book about a spec and i see something i guess i skimmed over. well the first and last friction plates are different(some kind of coating on them). the barnett clutchs all used the same friction plate regardless of order. well anyways i am stacking them in . well as it turns out according to the book the last friction plate is suppost to go in a different groove than the rest. i had not been doing this. however i do not really see the significance of placeing that plate in that slot, but it could very well have been my problem all along. we shall see. i am however a little to pissed off due to my recently aquired ticket while tring to adjust the clutch to work on it any farther.
Old Aug 23, 2005 | 01:37 PM
sl2racer's Avatar
alright she is back from the dead. the new clutch feels different than the others. kinda hard to describe. i am going to ride on this clutch for a bit before i drag her back to the track. i wanna be able to ride the thing for a bit and not have it end up like cecils. all ways in pieces.
Old Aug 23, 2005 | 02:08 PM
B16aTeggy's Avatar
My Balls Hurt
Burn!
bikes
-73 kawasaki z1 900/ 05 cbr600rr motor
-06 675 117whp 52fttq
AIM- B16aTeggy
Old Aug 23, 2005 | 02:29 PM
sl2racer's Avatar
burn??? what is that suppost to mean?
Old Aug 23, 2005 | 02:49 PM
Cecil's Avatar
gone fishin
OUCH!
Old Aug 24, 2005 | 04:41 AM
TNathe's Avatar
doh! sometimes learning is an expensive task. SO is racing though, you know that. G/L with this one and I will NOT jinx you this time, promise.
Old Aug 24, 2005 | 12:04 PM
sl2racer's Avatar
you better not tyler. you have made powers.
Old Aug 24, 2005 | 12:30 PM
TNathe's Avatar
muuuahahaha, dont f with me or ill pull out my voodoo doll of a bike and destroy anyones bike.
Old Aug 24, 2005 | 08:59 PM
BucWildBob's Avatar
school is expensive.. clutches, should be soaked in tranny fluid, or mc oil for a while before installing.. if you feel the plates, one side is sharp the other side is rounded.. figure out which side is suppose to go out and do it right. it will make a huge diff. and be sure to use mc specific oil. using car oil, it doesnt have the friction modifier in it and will cause clutch burn up and slipping clutches not to mention jerky launches
Old Aug 25, 2005 | 05:14 AM
954RR's Avatar
When I did the clutch on the F3 I used OEM Honda plates and Barnett springs and it has been great for 15k miles...including tons of clutch wheelies and 8k rpm drag launches. You DEFINITELY want to put them in the correct order according to the manual.
2002 954RR
-135rwhp
0-110mph in 6.7 seconds
