Auto-X/Road Racing Autocrossing, Road Racing & Other Forms of Sanctioned Racing
quick offset question
Old Aug 29, 2008 | 09:10 AM
blkackteg's Avatar
Now with more c5!
Default quick offset question
I'm looking into a set of 15" buddy club wheels for my integra. They come in +35 and +42 offset. I understand what the offset is, my question is: which offset would be most appropriate for an integra for auto-x purposes? Thanks.
Old Aug 29, 2008 | 09:41 AM
w0rd's Avatar
I don't think it makes a difference.
Jeremy
Old Aug 29, 2008 | 10:09 AM
jblaine's Avatar
Comprehensive
Whatever offset puts the centerline of the wheel where the OEM wheel's centerline was.
[ Stage Infinity ]
Old Aug 29, 2008 | 10:30 AM
blkackteg's Avatar
Now with more c5!
Ok, so the teg came with fat fives, which I believe are a 6" width with a +45 offset, the buddy club wheels are 6.5", and I am bad at math... which would be closer to oem the +35 or +42?
Old Aug 29, 2008 | 10:32 AM
Loren's Avatar
Less offset puts the wheel out further which gives you a more favorable geometry for handling. (But, taken too far, can overload wheel bearings, so you'd be wise to stay within 10mm of the stock offset)
You also need to consider fender clearance on the outside and suspension clearance on the inside.
Look at what you have on the car right now. Find out what the width and offset is. Measure your clearances inside and outside. A little quick math will tell you what will and will not fit... give or take 5mm or so.
You'll need to consider both the offset AND the width of the wheel, and what size tire you intend to run. Ultimately, wheel offset and tire width are what you need to know. (assuming that you're sticking with a tire size that keeps close to the stock tire diameter)
Old Aug 29, 2008 | 10:44 AM
jblaine's Avatar
Comprehensive
[ Stage Infinity ]
Old Aug 29, 2008 | 11:27 AM
blkackteg's Avatar
Now with more c5!
thanks all
