Need major help launching turbo car.. (more)
The MSD DIS-2 is what us distributorles DSM guys use. Teal Talon will attest to the fact that it works well.
I pity the fool that messes with mah 2-Step.
It works very well but traction isnt one of my big concerns. 7PSI of boost at the line.
http://www.msdignition.com/1disign.htm
If you put slicks on that thing it will either bog more or wheel hop more those cars are some of the trickiest to launch. I would experiment with skinnier tires and let them spin a little it will keep it in boost for the next gear. I am just going by how my friend used to launch his 87 just let the damn tires spin.That mph is pretty high you have 4mph on me in the 1/8th(when I was at 10psi running 14 now) but I had a 9.6 et. See how much of a difference a decent launch can make. I would say if you get that 60 below 2.2 you should be able to run like a 13.9 and a 9 flat in the 1/8th. But those cars are not dragracers midrange is their forte.
Originally posted by "Someone"
Originally posted by SR20DET
I will look and see if they make a 2-step for a distributor-less ignition......I read about a few of the various models on summits site and most will not work since I dont have one of those distributor thingees
Originally Posted by Someone
Originally posted by onefastb18c
Think about an MSD 2 step...
Larry
2002 MB C320 Sport Wagon 15.4@91
2002 Dodge Neon SE
1991 Dodge Spirit R/T-12.3@117 (at 368 whp) Now 500 whp / 514 ft lb on pump gas
Larry
2002 Dodge Neon SE
Thanks! Im going to check them out now.
Larry
2002 Dodge Neon SE
Larry
2002 Dodge Neon SE
lifelong learner
on
Z31s dont wheelhop.
Not any of the 8 ive ever driven have. your friend should replace his rear xmem bushings
rest in peace tim.
rest in peace tim.
