Words coming through subs--help--
Old Jan 13, 2010 | 12:13 PM
naha08's Avatar
Default Words coming through subs--help--
Got an old school ZR600 kicker amp mono to 2-kicker 10's.... Amp has the x-over module built in and I have it set to low pass. Phoenix gold amp install kit and pioneer head unit (just a basic install).
PROBLEM--- Getting words coming through the subs! They hit and sound good most of the time but occasionally there are words coming through.
Any help would be great. THX
Oh, I also had this same setup hooked up to 2 solo-baric 12's and this issue was not present then...
Old Jan 13, 2010 | 02:39 PM
tbay813's Avatar
sounds like the amp same thing happened 2 me with my old setup check the wires and see if any were crossed if not i would take it 2 a local shop n let them tell you whats wrong there a number of reasons that it could happen most shops will take a look at it n tell you whats wrong
Old Jan 13, 2010 | 04:51 PM
GradeA_TireFryer's Avatar
All American, rice eater!
adjust crossover on amp
Old Jan 13, 2010 | 05:43 PM
alphabets's Avatar
I ♥ ♫
Look for a setting on your amp called "crossover", "x-over" or "LPF" and adjust to the appropriate setting. Generally, it's 80hz for 12"s and around 60hz-70hz for 15"s. If you don't have this setting, you may be able to find it in your headunit in your sub-out settings.
lol, internet.
Old Jan 14, 2010 | 12:56 PM
naha08's Avatar
The amp has a removalbe x-over module which i do have set correctly at low-pass. You can not further adjust, just has low-pass, high-pass, and by-pass. Think I am just ganna add an inline x-over before the amp. THX for the help.
Old Jan 14, 2010 | 02:58 PM
CHUPA_CABRA_2.0's Avatar
I need a new gas gauge
it's Satan
facebook.com/modifiedstreetperformance
Old Jan 17, 2010 | 09:35 PM
wesry's Avatar
If you are getting words coming through on your subs than your built in crossovers on your amp is going out.
Old Jan 23, 2010 | 12:07 PM
Taco15's Avatar
most importantly what cd player do you have? do you have a sub output or only front and rear?
